Hey,
Does anyone know how to change the default save path for the exporter? In the rendering setting window I'm unable to change the default.
I would like to change the path from C:/Program Files/Google/Google SketchUp 6/Plugins/indigo/renders:\ to \\master\renderings.
i have done a search on this topic, something that I thought would be covered by this stage of the game and came up with no hits.
thanks for all the help.
-Post-
changing the Save path for the exporter
Look for this code:
Try changing to this:
I haven't tested this but it should work.
def image_path
if @path
return File.join(File.dirname(@path),"renders").gsub!(/\\/,"\/")
else
return nil
end
end
def image_path
return "c:\\your\\path\\goes\\here".gsub!(/\\/,"\/")
end
that alone doesn't seem to work for me.
that might set the image_path but it is never invoked or checked when starting the render (that i can tell anyway.) we need a way to get it called when hitting export.
help!
**edit**
ok so i got it to work by just adding it in right by the batch.puts for the autorender.bat
if we could make a new variable such as manual_image_path or mip or whatever that we could input (either manually or with a nice search function like when finding indigo.exe for the first use) then we can just do a file join, like it is done now, but add in the new path. anyway, i doubt this makes sense. if i knew how to declare variables i think this could be more helpful to everyone else. sorry for being confusing.
help!
**edit**
Whaat that code did not work for me neither.
cp: you have a lot more code knowledge then me. I'm just know to this whole indigo and ruby scripts thing.
But i did have an idea:
Is there a way to what the exporter accept a network name within the indigo_1_1_5path.txt file?
So right now it reads:
c:\Program Files\Google\Google SketchUp 6\Plugins\indigo\indigo.exe
are we able to get the skindigo to accept
\\master\Program Files\Google\Google SketchUp 6\Plugins\indigo\indigo.exe
if we are able to, i think the render button issue that I'm having would be solve. (the slaves are not able to find the path.)
I hope the above makes is not confusing, and yes cp i argee that it would be "nice
" to have a variable such as manual_image_path in the render settings.
Thanks very much for all yours helps
-Post-
-Post-
i run indigo from each slave ()I walk to each computer to set it up)
I have just noticed a typo:
thanks.
-Post-
Sould readc:\Program Files\Google\Google SketchUp 6\Plugins\indigo\indigo.exe
I will try and map a drive as you suggested in another thread, when i get some time.c:\Program Files\Google\Google SketchUp 6\Plugins\indigo\image.igi
\\master\Program Files\Google\Google SketchUp 6\Plugins\indigo\image.igi
thanks.
-Post-
