MAterial Database Question
4 posts • Page 1 of 1
SlimTrigger
Post by SlimTrigger » Sat Jun 14, 2008 5:20 am
Where do I need to put the files for when I download a texture from the mat database?
Post by fused » Sun Jun 15, 2008 12:34 am
you should import them in skindigo.
look out for sth thats called "import igm".
Post by neo0. » Fri Jun 20, 2008 12:01 pm
Which version supports IGMs?
Post by Whaat » Fri Jun 20, 2008 1:34 pm
version 1.1.5 has the best IGM support. it will continue to improve over time. You'll have to have some patience as the kinks get worked out. The biggest problem is that many of the materials that are currently in the database are not valid IGM files so they might not load properly in SkIndigo.
Be sure to download Indigo 1.1.5 if you are using SkIndigo 1.1.5 :)
