SkIndigo 4.4.10.1
SkIndigo 4.4.10.1
RBZ:
http://downloads.indigorenderer.com/dis ... 4.10.1.rbz
Windows Installer:
Changelog:
4.4.10.1
Added new fabric material type.
Fixed section plane export resulting in a scene load error.
Windows Installer:
Changelog:
4.4.10.1
Re: SkIndigo 4.4.10.1
Hi Ono!
In my case the parameters "Roughness" and "Sheen Weight" of the fabric material set in Skindigo, are not loaded into Indigo, which maintains the default parameters.
Hi OnoSendai,
I purchased Indigo recently, is there any plans to develop the Sketchup plugin so it will be more compatible with Sketchup same like the cinema 4d plugin ... Thanks.
This is working as intended, what's happening here is that you have selected 'SketchUp' in the map drop-down box. This means that the roughness and sheen weight paramaters are using the SketchUp texture map to control their values.
Do you mean an embedded plugin to SketchUp?
That is something we have though about and even experimented with.
How to set the "NULL" material in the material editor?
Hmm I'm not sure if there is an easy way to create a NULL material in SkIndigo currently.
Ok, then i will set it in indigo
Hi. I have noticed that the "UV Mapping " option is not workin anymore (https://www.indigorenderer.com/document ... uv-mapping). I've tried lots of times and 95% of the times is not working. Would you please take a look ?
Thx
Thx
Any News?Lal-O wrote: ↑Tue Feb 22, 2022 1:03 pmHi. I have noticed that the "UV Mapping " option is not workin anymore (https://www.indigorenderer.com/document ... uv-mapping). I've tried lots of times and 95% of the times is not working. Would you please take a look ?
Thx![]()
Hope to hear any updates soon.Lal-O wrote: ↑Thu Feb 24, 2022 12:50 pmAny News?Lal-O wrote: ↑Tue Feb 22, 2022 1:03 pmHi. I have noticed that the "UV Mapping " option is not workin anymore (https://www.indigorenderer.com/document ... uv-mapping). I've tried lots of times and 95% of the times is not working. Would you please take a look ?
Thx![]()
Me tooAlamy wrote: ↑Wed Mar 02, 2022 4:24 amHope to hear any updates soon.Lal-O wrote: ↑Thu Feb 24, 2022 12:50 pmAny News?Lal-O wrote: ↑Tue Feb 22, 2022 1:03 pmHi. I have noticed that the "UV Mapping " option is not workin anymore (https://www.indigorenderer.com/document ... uv-mapping). I've tried lots of times and 95% of the times is not working. Would you please take a look ?
Thx![]()
Hi,OnoSendai wrote: ↑Thu Jul 16, 2020 12:09 amRBZ:
Windows Installer:
Changelog:
4.4.10.1
the RBZ link above cannot be dowloaded, could you please provide a new link?
thanks!
Hi guys!
We have a serious problem...
Skindigo 4.4.10.1 doesn't work with the last version of Sketchup (2024). I tried to install and uninstall the program but the problem persist.
With the version 2023 the problem doesn't sussist.
I attach the string of the error!
<internal:C:/Program Files/SketchUp/SketchUp 2024/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb>:85:in `require'
C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/skindigo/skindigo_core.rb:80:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2024/Tools/extensions.rb:197:in `load'
C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/skindigo.rb:19:in `register_extension'
C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/skindigo.rb:19:in `<module:SkIndigo>'
C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/skindigo.rb:4:in `<top (required)>
We need an update of the exporter!
Thak you guys
Thak you guys
