Glass & Water test.
7 posts • Page 1 of 1
A_Minima
Glass & Water test.
Post by A_Minima » Tue May 15, 2007 3:01 am
I made two tests with the last Indigo (v7.0) & Skindigo exporter (v0.7.1).
It’s a simple scene with white background, physical Sky enable in export. Two differences between the renders :
Top with a single plane for water and bpt off / Bottom with an object (cylinder) for water and bpt on.
Glass with ior=1.52 and water with ior=1.33.
My regrets : no caustics projection on the “birds plane”. Cauchy Dispersion Coef. error or something else ?
This post is a "clone" of an other forum post I made (guess which...).
(edit)I mean an other forum from an other site...
A_Minima
The settings...
SmartDen
Post by SmartDen » Tue May 15, 2007 3:10 am
Set "Max Num Consec Rej"-parameter up to 1000 or higher. And have in mind, the caustics comes later with sun light.
Post by suvakas » Tue May 15, 2007 3:23 am
SmartDen wrote: And have in mind, the caustics comes later with sun light.
With bidir on the caustics should be instant with sunlight.
A_Minima
Post by A_Minima » Fri May 25, 2007 10:00 pm
Now I understand how to get caustics with glass & water, I've an other noob question : I tried to render coloured glass but without any success. The way I proceed : I give a colour (RGB : 0>X>255) but no expected result. Do I have to modify the xml file or something else ? :oops:
Post by Whaat » Sat May 26, 2007 4:49 am
For colored glass, it must have thickness and you must have transparency enabled. For more color (i.e. absorption), increase Sketchup opacity. For less color, decrease opacity. The correct opacity setting will depend on the thickness of the glass. If you still can't get it to work, please post an image of the Indigo render.
A_Minima
Post by A_Minima » Mon May 28, 2007 10:01 am
Yes, it makes sense !!
Stupid I'm. The confusion came from the fact I thought we have to set transparency to 0 for translucent material. So I thought just changing the color of the object was enought. I tried and It works fine. Just a precision for the others : don't push the opacity level to hight, you'll quickly obtain opaque materials.
Thanks, Whaat for your great contribution and for your good mood in any circumstences.
Regards
