like a liquid, with IoR 1.52, that weights less than vacuum, but more than air and catches alot vacuum beyond itself.
One problem with your mat: it's slightly white...
the only thing, you should get rid of, somehow...
And that's what I try to do, all the time, but to show good enough, you'd need to hardcore that to indigo...
a pure specular is more or less black + reflection... if you could ONLY get rid of black, which would ompletely turn to an alpha map, your reflections would look just fine.
Even coloured things would look as supposed...: the black part get's filtered, the colour stays...
But ok, for now, it can't be done... except, you recode indigo yourself xD
