All rendering software seems to afect sketchup's camera by changing the aspect ratio to suit your output resolution - but sketchup reflects this by putting grey shaded areas over the edges of your drawing.
We have a button "reset camera" that helps - but when a model has dozens of scenes, this can be time consuming to apply.
It is possible to prevent it happening in the first place?
I note this forum where a vray user has a fix for Vray - am wondering if a similar fix exists for Indigo
https://forums.sketchup.com/t/how-to-re ... en/7791/19
Thanks
Removing grey bars from Sketchup
Re: Removing grey bars from Sketchup
Has anyone found a fix for this? I'm currently finding it quite annoying!
Don't know if it's useful for you guys, but I usually use the "advanced camera" toolbar available in the sketchup menu. There's a button with an "X" and that always deletes all the grey bars.
The counterpart is that the perspective is changed, but it's usually enough to reduce the viewing angle
