I'm trying out the skatter extension, and when applying a grass structure to a group, the preview render window shows the grass just fine, but the main render window stays black. For several presets like daisies it works fine, but for grass I cannot seem to get this to work.
Any advice?
edit: seems when I disable gpu rendering, it does work. Using a GTX1080. Any idea?
Skatter extension : grass = black render
Re: Skatter extension : grass = black render
Hi, check the render log window and ensure that there are no errors showing there.
Been checking and testing a bit more. Seems this only happens when using skatter plugin to create grass or plans. When I disable the skatter content, the gpu acceleration works fine. Strange thing is though that on some designs it does work, and it gives me a black screen on others. Any idea? The log does not display any errors as far as I can see.
