SkIndigo 3.8.33.1
12 posts • Page 1 of 1
SkIndigo 3.8.33.1
Post by OnoSendai » Thu Feb 11, 2016 6:57 am
Changelog:
Added support for 'Skatter' plugin.
Fixed issue causing exception when Indigo could not be located.
RBZ: (Works on all platforms)
http://downloads.indigorenderer.com/dis ... 8.33.1.rbz
RBZ install instructions: http://www.indigorenderer.com/documenta ... o-rbz-file
Windows Installer:
Note for Sketchup 2016 users: The SkIndigo extension may need to be enabled in the Preferences. Please refer to the installation instructions.
Let us know if you hit any bugs!
cotty
Re: SkIndigo 3.8.33.1
Post by cotty » Fri Feb 12, 2016 7:10 am
OnoSendai wrote: Added support for 'Skatter' plugin.
Great news!
How can we use it?
STUDIO AARON
Post by STUDIO AARON » Fri Feb 12, 2016 8:45 am
Skatter is still in beta.
http://getskatter.com/
STUDIO AARON
Home Design, Rendering, Animation, and Virtual Reality
cotty
Post by cotty » Fri Feb 12, 2016 9:12 am
The question was about the usage with Indigo.
Post by Pibuz » Tue Feb 16, 2016 10:17 am
The question is good.
I bought it and I want to use it :mrgreen:
Juju
Post by Juju » Tue Feb 16, 2016 6:53 pm
what it says "on the tin", Indigo "render only" integration accomplished
Post by Pibuz » Tue Feb 16, 2016 7:55 pm
Ehm...what? :mrgreen:
Post by OnoSendai » Wed Feb 17, 2016 1:41 am
Just do some scattering with Skatter. Make sure to select 'use full geometry' not 'use proxies' when using a preset. Then export as normal and you should see the instances.
cotty
Post by cotty » Sun Feb 21, 2016 7:06 am
So there's no proxy scattering available?
Post by zeitmeister » Sun Feb 21, 2016 11:24 pm
Indigo uses it's own instances... so theres no advantage here for RAM consumption... exept in SketchUp, I presume.
Cheers, zeiti
Post by Pibuz » Mon Feb 22, 2016 10:20 pm
I'm studying a little and it works thanks a lot Ono!
Post by neo0. » Thu Mar 03, 2016 9:38 am
Having a problem. The material editor isn't switching over to the material i selected with su's editor. Im using the mac version. Switched finally :D :)
Users browsing this forum: No registered users and 114 guests
