skindigo wont load
6 posts • Page 1 of 1
nzjason
skindigo wont load
Post by nzjason » Fri Jun 20, 2014 12:09 pm
Hi all,
Have been using indigo for sketch up for a while now and this problem has just started with SU make 2014.
Basically if i open a .skp file from my desktop SU opens but has a host of load errors (screen shot attached).
Then the skindigo dialog is missing from my toolbars.
However if i open SU first then navigate via the file:open etc etc the file opens fine and the skindigo dialog is right were it should be.
Has anyone else experienced this?
Win7 pro 64Bit
Intel i7-3930K @ 3.2ghz 32gb memory
Sketch up make 2014, Indigo 3.6.28
Juju
Re: skindigo wont load
Post by Juju » Mon Jun 23, 2014 11:32 pm
I have not experienced problems, however I understand SU2014 (SU2013 probably as well, not sure though) doesn't like it (errors occur) when you double select a SU file to open it, rather open SU and open files using the program interface.
nzjason
Post by nzjason » Tue Jun 24, 2014 10:10 am
thanks JuJu. simple enough to work around. just a little frustrating. :D
Post by OnoSendai » Tue Jun 24, 2014 11:09 am
This is a SketchUp bug that has been fixed by Trimble already, I don't think they have released an update with the fix yet though,
cotty
Post by cotty » Tue Jun 24, 2014 11:40 pm
This one was fixed with the version 2014 M1 some days ago:
"Fixed an issue where launching SketchUp by double-clicking a skp file on another drive would corrupt $LOAD_PATH and render the Standard Library inaccessible. This bug caused many people to run into plugin loading problems if they were opening files located on drives other than their “C:” drive."
(http://www.sketchup.com/intl/en/developer/docs/releases)
nzjason
Post by nzjason » Thu Jun 26, 2014 2:19 pm
thanks guys, have just updated SU and all is fixed.
