problems with transparency
10 posts • Page 1 of 1
tigartos
Post by tigartos » Tue Jan 29, 2013 7:54 pm
I apologize if this topic has been around, but I'm tired of searching a solution.
I need to make clear water for the pool, which will transmit light. I installed the material Rippled water, but it does not transmit light.
What is my mistake? How to fix it?
Re: problems with transparency
Post by Zom-B » Wed Jan 30, 2013 2:25 am
change rendermode to MLT+Bidir :)
tigartos
Post by tigartos » Wed Jan 30, 2013 2:42 am
Zom-B wrote:change rendermode to MLT+Bidir :)
I use this method, but it does not work
Post by CTZn » Wed Jan 30, 2013 2:49 am
Also make sure that the water surface is intersecting the pool walls a bit in order to secure a closed volume.
tigartos
Post by tigartos » Wed Jan 30, 2013 3:44 am
CTZn wrote:Also make sure that the water surface is intersecting the pool walls a bit in order to secure a closed volume.
Thank you very much, everything was as I wanted
Post by Zom-B » Wed Jan 30, 2013 3:53 am
tigartos wrote:Thank you very much, everything was as I wanted
If you think so, then show me the sun shining inside your pool :P
tigartos
Post by tigartos » Wed Jan 30, 2013 4:39 am
you are right
It's not as good as I expected, the water looks realistic only when it does not get sunlight.
Post by Zom-B » Wed Jan 30, 2013 4:45 am
tigartos wrote:you are right
This is a general Problem with PathTracing, Sun light and specular materials.
Post by Headroom » Wed Jan 30, 2013 12:49 pm
Yup, pathtracing and caustics don't mix we'll.
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
Post by Pibuz » Wed Jan 30, 2013 10:04 pm
Also, the water material shoud have less opacity since it's a very thick solid and color absorption is proportional to thickness.
Users browsing this forum: Bing [Bot] and 36 guests
