how to?
7 posts • Page 1 of 1
Reaversword
how to?
Post by Reaversword » Thu Jan 31, 2008 12:49 am
Hi, I'm new in Indigo community. I'm Maya user.
I've been trying install indigo in 8.5 version, and I've get install it, but the 4th button, the exit portals button don't appear me, and when I invoke the material editor, and error pop up with "couldn't find mtimaterial editor".
For the last, I have try the last release of 23-01-2008. But then, when i open Maya and run mti_Main, gets me an error with "no mti_Main found".
I'm doing something wrong?
I should use Indigo 0.91, shouldn`t I?
I don't know if with all versions of all distributed for the web i'm doing something wrong.
Please, can anyone post the links to the newest & stable versions of all files needed?. Thanks for all
dougal2
Post by dougal2 » Thu Jan 31, 2008 1:01 am
The 23rd Jan MtI release is designed for Indigo 1.0.6.
Indigo 1.0.6:
http://www.indigorenderer.com/joomla/fo ... php?t=3479
MtI 1.0.6:
http://www.indigorenderer.com/joomla/fo ... php?t=3488
You should use the revision 200 version that I released today if you're intersted in Exit portals. It's broken in previous releases.
Finally, I made some tutorial videos on how to set it up properly:
#1 http://www.indigorenderer.com/joomla/fo ... php?t=3123
#2 http://www.indigorenderer.com/joomla/fo ... php?t=3141
Hope that helps.
Reaversword
Post by Reaversword » Thu Jan 31, 2008 2:52 am
Thanks dougal2.
Just I've tryed the new revision 200 on indigo 0.91 and it works with exit portal, but within NK data and IES attribute.
I see that exist a newer indigo (1.06). Ok. I'm gonna feed al the info you have posted. Thanks again!.
Post by Zom-B » Thu Jan 31, 2008 6:14 am
Dougal, you should have a announcement on the Maya Forum with exactly this Informations, so new Maya users can easily find this Maya2Indigo starter Pack!
Maybe a good idea for each Exporter Forum :idea:
dougal2
Post by dougal2 » Thu Jan 31, 2008 6:36 am
yup, I've been thinking this too.
psor
Post by psor » Thu Jan 31, 2008 7:14 am
Ya, ... every coder should have the right to make "sticky" posts in his
sub forum. You guys should ask Nik about this, it's so easy to do ... ;)
take care
psor
"The sleeper must awaken"
dougal2
Post by dougal2 » Thu Jan 31, 2008 7:47 am
I did pop into the IRC earlier. Apparently I missed Nick by about half an hour. I'll ask tomorrow.
