ISL shader nodes
ISL shader nodes
hey, ive been working two Indigo Shader Language nodes(namely ISL nosie, for perlin and fbm, and ISL blend, for blending multiple ISL shaders) for c4d so you can use ISL without actually having to write a single line of code.
Here are a few shots:
Re: ISL shader nodes
I love the displacement stuff. Good work fused!
take care
psor
take care
psor
"The sleeper must awaken"
gradient shader node
- 1710146017101461.jpg (23.33 KiB) Viewed 8487 times
- zeitmeister
Geilgeilgeil... wie ich mich darauf freu!
well... dont get too excited.... currently you can only do 2 color gradients with linear interpolation, because multi colored with non linear (c4ds gradients can be non linear) are a bit tricky (espacialy if the number of color varies).
- zeitmeister
Naja dann: MaGucknMaGucknMaGuckn.
Thanks Fused
- juan_irender
Very promising, Fused! Well, for doing proper multi-color interpolation, an spline data-type added to ISL (a la Renderman) would be very useful.
C4D R18 Studio user
Blender user
Blender user
First try to get a ISL generated Mountain done. Controle via direct Shader is 10000 times more comfy then tweaking the ISL code
I hope for more advanced tests over the Weekend... now its time for "Weihnachtsmarkt" *prost*
- zeitmeister
Oh, da sachste was... gleich wirds ja ernst. *hicks*
hey ZomB, you will be able to create MUCH better mountains with the next version
circular gradient and fbm. note that ALL the shader code is generated by Cindigo and you dont have to write a single line
the shader code:
the shader code:
<material>
<name>Indigo Material_mid0</name>
<diffuse>
<albedo>
<constant>
<rgb>
<rgb>0.800000 0.800000 0.800000</rgb>
<gamma>2.200000</gamma>
</rgb>
</constant>
</albedo>
<displacement>
<shader>
<shader>
<![CDATA[def Vec3ToReal(vec3 v) real : ((doti(v) + dotj(v) + dotk(v)) / 3.0)
def noise01(vec3 v) real : ((noise(v) + 1.0) * 0.5)
def noise01(vec2 v) real : ((noise(v) + 1.0) * 0.5)
def noise01(real r) real : ((noise(r) + 1.0) * 0.5)
def fbm01(vec3 v, int oc) real : ((fbm(v,oc) + 1.0) * 0.5)
def fbm01(vec2 v, int oc) real : ((fbm(v,oc) + 1.0) * 0.5)
def fbm01(real r, int oc) real : ((fbm(r,oc) + 1.0) * 0.5)
def mulCompVec2(vec2 a, vec2 b) vec2 : vec2(doti(a) * doti(b), dotj(a) * dotj(b))
def mulCompVec3(vec3 a, vec3 b) vec3 : vec3(doti(a) * doti(b), dotj(a) * dotj(b), dotk(a) * dotk(b))
def eval() real: (Vec3ToReal(lerp(vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, 0.00000, 0.00000), length(vec2(0.5,0.5) - getTexCoords(0)) * 2.0 )) * 1.00000 + 0.25000 * fbm01(mulCompVec2(getTexCoords(0) * 10.0, vec2(1.00000, 1.00000)),8)) * 1.50000]]>
</shader>
</shader>
</displacement>
</diffuse>
</material>Re: ISL shader nodes
added some perlin to make it more random!
<material>
<diffuse>
<albedo>
<constant>
<rgb>
</rgb>
</constant>
</albedo>
<displacement>
<shader>
<shader>
def eval() real: ((Vec3ToReal(lerp(vec3(1.00000, 1.00000, 1.00000), vec3(0.00000, 0.00000, 0.00000), length(vec2(0.5,0.5) - getTexCoords(0)) * 2.0 )) * 1.00000 + 0.35000 * fbm01(mulCompVec2(getTexCoords(0) * 10.0, vec2(1.00000, 1.00000)),8)) * 1.50000 + 1.00000 * noise(mulCompVec2(getTexCoords(0) * 10.0, vec2(0.25000, 0.25000)))) * 1.00000]]>
</shader>
</shader>
</displacement>
</diffuse>
bigger, closer. 13.000.000 tris.
- bigger closer.jpg (202.36 KiB) Viewed 8342 times
Users browsing this forum: No registered users and 67 guests
