environnement .exr + lights
2 posts • Page 1 of 1
SCHMUMS
Post by SCHMUMS » Thu Feb 07, 2013 1:23 am
Hello everyone, I'd like to know if it is possible to have a scene 4d environment. Exr with lights (spots) as well as dissemination materials (neon). I've tried several times but when I ride the intensity of my materials envirronnement the neon disappears.
Someone there a solution to my problem?
thank you in advance
C4DR11.5-R12 user-Quad core Intel Xenon 2X2,26 GHZ
Zbrush 4
galinette
Re: environnement .exr + lights
Post by galinette » Thu Feb 07, 2013 2:45 am
Actually you can, but the light output is probably very different (your environment is probably much much more powerful than lights), and you are probably using Reinhard Tonemapping, which auto-exposes the scene. Then when you switch on the environment , the tonemapper reduces exposure a lot, making the visible output of other lights close to zero. A little bit as if you try to look at stars during the day. I think this is the n°1 question on Indigo forums! There should be a FAQ...
I saved time today : two answers in one using copy-paste :)
Eclat-Digital Research
http://www.eclat-digital.com
