Cindigo 2.2.1 Beta 1
Re: Cindigo 2.2.1 Beta 1
im having a few problems building for R10.5 mac x64. this should be possible, or not?
okay... since it to works with R11 I assume that R10.5 just doesnt support x64 under OSX.
- pixie
I think that it could be it. I've seen plugins that needthe bump to 11 in mac to work.fused wrote:okay... since it to works with R11 I assume that R10.5 just doesnt support x64 under OSX.
Well... tried with Indigo 2.0.12 and 2.21 with Cindigo 2.0 stable and EXRs background light worked fine, but with Cindigo 2.2.1 both versions of Indigo crashed. So I think this is a Cindigo 2.2.1 bug.
btw I'm using the 64 bit widows version.
ok, going to have a look at it.
mac builds!
R10.5, R11 and R11.5.
pc versions are also updated, a few minor fixes.
Hi fused, I leave you the igs file and the c4d file so you can check the exr crash on R11 Win x64
- PRCindigo2.21.zip
- (14.83 KiB) Downloaded 429 times
Hello again, I found that when I add this:
<tex_coord_generation>
<spherical>
<rotation>
<axis_rotation>
<axis>0.000000 0.000000 1.000000</axis>
<angle>0.000000</angle>
</axis_rotation>
</rotation>
</spherical>
</tex_coord_generation>
to both background material and emitter material definitions EXR work fine in Cindigo 2.21 igs file
<spherical>
<rotation>
<axis_rotation>
</axis_rotation>
</rotation>
</spherical>
Ah, yes... that makes sense. Looks like i forgot to add that back in. Thanks Rafaello, will fix!
- pixie
Just a quick test to check native c4d material with alpha being converted flawlessly to indigo. This test was performed in C4d11.5 and no ivy was hurt.
- ivy.jpg (157.64 KiB) Viewed 12034 times
nice test pixie
- pixie
SpreadRock ROCKS!
- SpreadRock.jpg (114.53 KiB) Viewed 11957 times
- juan_irender
Hi Pixie.
How have you used SpreadRock in this test image?
C4D R18 Studio user
Blender user
Blender user
- pixie
I know that there's a free plugin from the same author, yet I bought the SurfaceSPREAD plugin so it might not apply to the free version. It's rather simple, I add the SPREADrock object, set to custom (instead of default sphere) and then drag the object I want to have some noise. Set the displacement amount, the noise and it's backedjuan_irender wrote:Hi Pixie.
- PureSpider
