Cindigo 2.0.5 - beta 1
Post by fused » Mon May 11, 2009 3:46 am
for Indigo 2.0.5
(compatible with Indigo 1.1.18)
download exporter:
Cindigo 2.0.5 beta 1.zip
PC R10
(3.2 MiB) Downloaded 560 times
Pc Version R9 - soon
Mac Version - soon
The PC version contains plugins for R10(32 and 64 bit).
Make sure you have the newest version of quicktime installed! Previews will not work with the 64 bit version bacause of the lack of 64 bit quicktime.
Good beginner tutorials can be found here (german and english, a bit outdated), a video tutorial for beginners here
The Cindigo Blog
changelog wrote:Cindigo 2.0.5:
* fixed sun bug
* fixed sphere bug
* fixed light type recognition
* lots of internal improvements
* complete rewrite of the expor routine, again
* c4d lights can be controled by a light tag now
* readded light tag
* changed displacement_error_threshold default to 0.0
* readded igm export and material previews
* if indigo 2.0 is installed the path will always be read from the registry
* exponent texture param b will be equal to exponent value on export
* added scene scale selection, defaults to the currently set scene scale in c4d
* removed box filter from splat and downsize
* added gaussian filter to downsize
* added export of the c4d spot light with a default.igs file
* added export for all other c4d area light types (except line)
* added export of the c4d omni light
* added export of c4d area lights with a linked object
* made render settings a video post (moved to reder settings)
* layed ground for getting the path from the registry
* added motion blur export, needs some fixup (also now broken)
* fixed crash when no c4d material is applied to a mat helper
WARNING: Its a beta and quite a lot settings in the export window are not used or broken (animation export, seperate materials/settings, etc). theres also some stuff missing (indigo instances, etc.). But the stuff that works at the moment works quite well :)
iestest.zip
Spotlight test scene
(33.02 KiB) Downloaded 359 times
Re: Cindigo 2.0.5 - beta 1
Post by fused » Mon May 11, 2009 3:57 am
attached c4d spot light test scene.
Post by fused » Mon May 11, 2009 4:43 am
theres a bug with sunsky reported by Stromberg, will fix later, busy now.
iluxa
Post by iluxa » Mon May 11, 2009 6:31 am
i got such
Error: SceneLoaderExcep: TinyXmlWrapper: Parse error while parsing double from '0.010000 0.010000 0.010000'
from indigo 2.0.5 / c4d 11.027 win32
scene attached
manulIND.rar
(24.02 KiB) Downloaded 357 times
Post by fused » Mon May 11, 2009 6:34 am
iluxa wrote:i got such
scene attached
fused wrote:theres a bug with sunsky reported by Stromberg, will fix later, busy now.
dont use the sun for now :)
edit: ok maybe its not the sun, will have a look at it later
edit2: ok i fixed it. was something about spheres, will upload later
iluxa
Post by iluxa » Mon May 11, 2009 6:50 am
Thanks for exporter and reply!
BTW: no sun, i have night :D
merged scene(previous version) but nothing.
Yves it still write it <!--Generated by Cindigo 1.1.18-->
Thanks
Post by pixie » Mon May 11, 2009 6:57 am
Holly Smocking!! :shock:
Post by fused » Mon May 11, 2009 7:06 am
iluxa wrote:Yves it still write it <!--Generated by Cindigo 1.1.18-->
yeah i was lazy :)
will upload a fixed version (except the comment :) ) any minute
Post by pixie » Mon May 11, 2009 7:11 am
yeah i was lazy :)
Light system seem to be broken :(
Don't forget to change the default procedure for enter in the preview window ;)
iluxa
Post by iluxa » Mon May 11, 2009 7:14 am
yeah i was lazy :)
Great!
don't forget another great features of CIndigo for future updates :wink:
Post by fused » Mon May 11, 2009 7:15 am
fixed and uploaded:
changelog wrote:* fixed sun bug
* fixed sphere bug
iluxa
Post by iluxa » Mon May 11, 2009 7:51 am
wonderful, i just play with Light-Layers.
is this bug of indigo?
i stay to render for 8 min but lamp-object(with question mark) still have not emit light. Only ies-ligts emit.
all lights was exported(i check out igs-file).
Post by pixie » Mon May 11, 2009 8:01 am
The only thing lacking is layers... :(
iluxa
Post by iluxa » Mon May 11, 2009 8:07 am
pixie wrote:The only thing lacking is layers... :(
what's wrong?
Post by pixie » Mon May 11, 2009 8:18 am
what's wrong?
How does one set those?
Users browsing this forum: No registered users and 70 guests
