Cindigo 1.0 - beta 2
Azrael Crusader
Post by Azrael Crusader » Sat Jan 19, 2008 9:29 am
OS is Win Xp SP2 and it is the 32bit-Version of cinema...
Marcofly
Post by Marcofly » Sat Jan 19, 2008 10:38 am
@Azrael: don't use the latest Indigo version, use the 1.0.2, that fits the Cindigo 1.0.2 version!
unzip the cindigo in the c4d\plugins folder. You'll have a *.cdl file and a *cdl_R10 file. Delete the first, rename the second to *.cdl.
Start cinema again, it should work
@kada: 0,01!!!!!!!!!!!! :wink: there's a HUGE difference.. you don't see the 4 metal things because they're out of focus (and reflecting the sky, they have its colour)
Azrael Crusader
Post by Azrael Crusader » Sat Jan 19, 2008 10:51 am
I did exactly what you are describing...3-5 times... There is nothing...
kadajawi
Post by kadajawi » Sat Jan 19, 2008 11:02 am
whoops, yes, I meant 0,01.
Hm, Indigo 1.0.5 works fine here.
Strange. Make sure to remove every other Cindigo version except the newest one out of the plug-ins folder. Other than that... no idea.
Azrael Crusader
Post by Azrael Crusader » Sat Jan 19, 2008 11:05 am
Yes I've done this... I also tried an older version (the "0.8") and this works fine... No idea why... But with new version and also the 1.0.1 it is not working...
Post by fused » Tue Jan 22, 2008 1:19 am
hey azrael,
im sorry for the inconvenience, but at the moment i dont think i can help you.
your problem is a known issue and im trying to work it out...
maybe you can try that:
- are you sure you activated quicktime in c4d?
- (if its not too much) try to load cindigo in a fresh installed, unpatched c4d R10, then with patches.
Micha1138
Post by Micha1138 » Tue Jan 22, 2008 5:15 am
Hey Az, just for kicks, why don´t you a) compare the bytesize of the files of the 10 and 9 exporters, and put them both into the plugin folder ? And then just check whether one of them gets listed at start up or not ;) Maybe its just a little something that´s wrong !
Oh,and no, not trying to wisecrack here, just totally giddy because the exporter works so well (although I still have to figure out a few things ;) )
Michael
Azrael Crusader
Post by Azrael Crusader » Sat Jan 26, 2008 1:37 am
Hey guys,
thanks for the tips...
@fused: Don't worry, I'm just glad it isn't my mistake...
:D
@Micha: I've tried almost everything...
Lets see, may be it is working with the new version...
Azrael Crusader
Post by Azrael Crusader » Sun Jan 27, 2008 12:41 am
Hy guys,
Good news! It is working right now with Cindigo 1.0.6!!
Cheers
Chris
Post by fused » Sun Jan 27, 2008 12:53 am
Great! :)
Locked
