Hi!
I have a short question about the exporter. For 2 months ago, I used the exporter successfully, but today I have a problem. I create some "non-standard-geometry-objects" so the exporter has to create 3ds files.
When I place an object-Tag from the indigo exporter on the object, its like, that the exporter forget to create it. I don't know why. If I place an light-tag on it, it will be exported.
I tried versions vom 59.4 - 59.7. Everytime tHe same problem... Could someone help me what I can do? I use C4D 9.601
Exporter "forgets" to export objects
Thank you very much! It wokrs
I knew that there was something, but i didn't know what^^
Last question. Does anyone know, why c4d quits with an error message when I want to export the indigo files. My scene has many objects, but only "geometry" objects and one material + render settings object + the light-geomtry object.
Does anyone know? THANKS A LOT!
