Indigo for Cinema 4D 4.4.13.1
Re: Indigo for Cinema 4D 4.4.13.1
this is only the way to get right focus with cindigo exporter > standalone app (changing focus object with keyframes, with indigo compositing tag > invisible object):
- zeitmeister
Now I've got your point!
Indeed focus object distance is not being exported correctly for animations when linked in the camera options... in R20 here.
Seems like values are not being read by Cindigo or, what I presume, written at render time properly by C4D.
Because it does work in IPR and VIPR.
But there's no need for keyframes: just use my little expresso thingy; it should work.
If you use a null object as focus target, there’s no need for hiding it via indigo compositing tag also.
Check it out!
Check it out!
okey thanks!zeitmeister wrote: ↑Fri Dec 25, 2020 10:11 pmNow I've got your point!
Check it out!
focusbug_with_spikes_expresso.zip
why does cindigo exporter works only with absolute file pathes? can you add "exporting with relative pathes" function in igs/igq? i have to change in manual mode via notepad++ "c:\\" pathes on laptop to "\\networknameofmaschine\\" if i want to open igq/igs on home tower pc.
- zeitmeister
Yeah it should be optional.
In the meantime you could pack a PIGQ or PIGS from the standalone, take it to another machine and open it there.
- pixie
damn zeitmeister, you seem to have solution for everything! xD Happy holidayszeitmeister wrote: ↑Mon Dec 28, 2020 11:01 pmYeah it should be optional.
- zeitmeister
Erm no... but spare time. ^^
Happy holidays!
Happy holidays!
no, i can't (look to the scene folder size):zeitmeister wrote: ↑Mon Dec 28, 2020 11:01 pmYeah it should be optional.
thanks, will try.zeitmeister wrote: ↑Fri Dec 25, 2020 10:11 pmNow I've got your point!
Check it out!
- zeitmeister
Sorry, my Russian is a bit non-existent.
PIGS will compress the files. You tried to open indigo standalone, choose „Tools“, and then „Pack Indigo Scene/Queue/Material“?
What filesize do you get in result?
it was a screenshot of 130Gb scene folder with 55000 files.zeitmeister wrote: ↑Tue Dec 29, 2020 11:55 pmSorry, my Russian is a bit non-existent.
- zeitmeister
... and compressed as pigs?
- zeitmeister
You made me curios.
So if you can’t transfer that pigs the only way remains editing the filepaths externally.
But as I said, it should definitely be an option.
i just change file pathes in Notepad++'s batch mode from "c:\\" to ""\\mylaptoppc\", then it's possible to open the igq scene via local network on my rtxs tower pc via Windows Explorer. but it's a trick, not a normal exporter's function.zeitmeister wrote: ↑Thu Dec 31, 2020 7:53 pmYou made me curios.
Users browsing this forum: No registered users and 64 guests
