Indigo for Cinema 4D 4.4.13.1
Post by fused » Wed Sep 16, 2020 11:03 am
R20 version supported: R20.059
R21 version supported: R21.207
S22 version supported: S22.118
R23 version supported: R23.008
Windows:
Indigo Renderer:
indigo-for-cinema-4d-4.4.13.1-installer.exe - Includes installers for R12 - R19
indigo-for-cinema-4d-R20-4.4.13.1-installer.exe - Includes installers for R20 - R23
Indigo RT:
indigo-rt-for-cinema-4d-4.4.13.1-installer.exe - Includes installers for R12 - R19
indigo-rt-for-cinema-4d-R20-4.4.13.1-installer.exe - Includes installers for R20 - R23
Mac:
Indigo Renderer
indigo-for-c4d-4.4.13.1-R12-mac.zip
indigo-for-c4d-4.4.13.1-R13-mac.zip
indigo-for-c4d-4.4.13.1-R14-mac.zip
indigo-for-c4d-4.4.13.1-R15-mac.zip
indigo-for-c4d-4.4.13.1-R16-mac.zip
indigo-for-c4d-4.4.13.1-R17-mac.zip
indigo-for-c4d-4.4.13.1-R18-mac.zip
indigo-for-c4d-4.4.13.1-R19-mac.zip
indigo-for-c4d-4.4.13.1-R20-mac.zip
indigo-for-c4d-4.4.13.1-R21-mac.zip
indigo-for-c4d-4.4.13.1-S22-mac.zip
indigo-for-c4d-4.4.13.1-R23-mac.zip
Indigo RT
indigo-rt-for-c4d-4.4.13.1-R12-mac.zip
indigo-rt-for-c4d-4.4.13.1-R13-mac.zip
indigo-rt-for-c4d-4.4.13.1-R14-mac.zip
indigo-rt-for-c4d-4.4.13.1-R15-mac.zip
indigo-rt-for-c4d-4.4.13.1-R16-mac.zip
indigo-rt-for-c4d-4.4.13.1-R17-mac.zip
indigo-rt-for-c4d-4.4.13.1-R18-mac.zip
indigo-rt-for-c4d-4.4.13.1-R19-mac.zip
indigo-rt-for-c4d-4.4.13.1-R20-mac.zip
indigo-rt-for-c4d-4.4.13.1-R21-mac.zip
indigo-rt-for-c4d-4.4.13.1-S22-mac.zip
indigo-rt-for-c4d-4.4.13.1-R23-mac.zip
Changelog:
* Fixed crash on certain meshes.
* Render Settings light layer UI always updates when num layers changed.
* R20+: Open materials and light tags also update their layer selection dropdowns.
* R23: Added basic support for C4D scene nodes.
Originalplan®
Re: Indigo for Cinema 4D 4.4.13.1
Post by Originalplan® » Wed Sep 16, 2020 11:15 am
To put it blunt. F*ck yes!!
Great job.
yonosoy
Post by yonosoy » Wed Sep 16, 2020 12:57 pm
Thank you!
Waiting for code in the absorption ans SSS definition, the inclusion of mie cumulus as phase function, the inclusion of maximum extincion coefficient value, ...
Thanks again.
Ilay
Post by Ilay » Wed Sep 16, 2020 4:41 pm
Thank you!
I'm sorry for my bad English
Post by fused » Thu Sep 17, 2020 12:52 am
Thank you!
Thanks again.
I have added a ticket for that, will happen eventually. I really have to do some work on 3ds max now :)
yonosoy
Post by yonosoy » Thu Sep 17, 2020 1:11 am
Thanks fused!
Post by pixie » Thu Sep 17, 2020 1:12 am
Thank you!
wob
Post by wob » Thu Sep 17, 2020 3:24 am
very nice. still waiting for scatter.
wob
Post by wob » Thu Sep 17, 2020 3:39 am
another very old "classic" problem of indigo. alpha channels work very very very bad:
it depends too much on GPU Max Ray Depth parameter. In complex scenes this problem appears up to 10 (!) GPU Max Ray Depth (10 MRD - it means long rendering time). And you never know when it will appear on your renders!
In this scene (just clouds in scene), problem appears from minimum - 4 - GPU Max Ray Depth. Scene file:
CLOUDS_ALPHA_TROUBLE.zip
(144.76 KiB) Downloaded 752 times
also the same behavior of indigo - with indigo compositing tag (invisible to camera parameter). you always have the risk of seeing the shadow of an invisible object on your render ;)
Post by fused » Thu Sep 17, 2020 5:38 am
I guess this is a general Indigo bug, it would be convenient if you posted those here: https://www.indigorenderer.com/forum/viewforum.php?f=5
Thanks,
Yves
Post by fused » Thu Sep 17, 2020 7:55 am
I tried the scene and it is missing the could texture. Could you export the scene to indigo and save it as a .pigs? That way I can file a bug.
Thank you.
wob
Post by wob » Thu Sep 17, 2020 8:28 am
Thank you.
the texture is included in archive. how to quickly change missing textures in cinema 4d:
https://www.youtube.com/watch?v=Funajp9uyCA
wob
Post by wob » Thu Sep 17, 2020 8:31 am
Thank you.
pigs:
(46.22 MiB) Downloaded 902 times
Post by fused » Thu Sep 17, 2020 9:03 am
Check again, it is not. :)
Thanks for the pigs.
wob
Post by wob » Thu Sep 17, 2020 9:11 am
i tested just now multi-gpu 4.4.13 fix (for 2 cores CPU), and can say, indigo can render picture with 3 gpu and one 2 core processor now (pentium g4400). but gpu utilization with 3 gpu cards is lower (cpu utilization is 100%), than with 2 cards (cpu utilization is 85-90%). i'm afraid, system with 4 cards will give even lower performance than with 3 cards, so, now 2 cards configuration seems much better for low-priced cpus even with this good 4.4.13 update.
2 cards:
3 cards:
