HI all
I can not render from IGI
Is this a bug ?
I test it on 3 onother Files .. the same result
That's my message *JPG*
Cheers
IGI Problem
Re: IGI Problem
Seems you have changed something in your parameters. I think you will need to choose the same settings for your render like it is saved in the IGI, for exampel resolution and and supersampling.
Probably others will know better...
24 hours isn't enough
http://www.werkraum3d.com
Re: IGI Problem
THX ..
Yes i delete one Light Layer
Layer name1 LED
I change the Settings at the Light Layers
Now It works
Cheers
Layer name1 LED
Now It works
Cheers
