need help with Cinema4D fresnel
Re: need help with Cinema4D fresnel
Post by OnoSendai » Thu Apr 11, 2013 2:00 am
	<material>
		<name>mat1</name>
		<diffuse>
			<texture>
				<path>blackrose_pattern.jpg</path>
				<uv_set>default</uv_set>
				<exponent>2.2</exponent>
			</texture>
			<texture>
				<path>../italy_bolsena_flag_flowers_stairs_01.jpg</path>
			</texture>
			<albedo>
				<shader>
					<shader>
						<![CDATA[
def eval(vec3 pos) vec3 :
  let
    uv = getTexCoords(0)
  in
    lerp(
      sample2DTextureVec3(0, uv),
      sample2DTextureVec3(1, uv),
      minCosTheta()
					</shader>
				</shader>
			</albedo>
			<random_triangle_colours>false</random_triangle_colours>
			<layer>0</layer>
		</diffuse>
	</material>
N.G.
Post by N.G. » Thu Apr 11, 2013 2:13 am
what did I do wrong?
<material>
<name>mat1</name>
<diffuse>
<texture>
<path>L:\Indigo\tex\14_5_17_d.jpg</path>
</texture>
<texture>
<path>L:\Indigo\tex\14_5_15_b.jpg</path>
</texture>
<albedo>
<shader>
<shader>
<![CDATA[
let
in
lerp(
minCosTheta()
</shader>
</shader>
</albedo>
<layer>0</layer>
</diffuse>
</material>
error
Post by Zom-B » Thu Apr 11, 2013 2:32 am
N.G. wrote:what did I do wrong?
You've put IGS code into the ISL Editor :)
Only put that code into the editor:
  let
  in
    lerp(
      minCosTheta()
Now define two textures in the first both fields above the Code window.
The Problem about minCosTheta Ono is that the result isn't fresnel but something else...
Indigo minCosTheta()
C4D fresnel
N.G.
Post by N.G. » Thu Apr 11, 2013 2:44 am
honestly, I realized that nothing I do not understand anything. I need an example. Please give me your shader. :roll:
when I see program code-brain off. :lol:
Post by Zom-B » Thu Apr 11, 2013 2:48 am
Here you go:
N.G.
Post by N.G. » Thu Apr 11, 2013 2:55 am
Zom-B wrote:Here you go:
I love you! :lol:
it works!
N.G.
Post by N.G. » Thu Apr 11, 2013 3:07 am
YES.
Post by fused » Thu Apr 11, 2013 3:08 am
While it looks like it will just work like that, as soon as you add any other texture to that material, it will break.
Unfortunately, due to the way Indigo's material system works, referenceing textures in ISL shaders is a bit tricky (referencing is actually easy, maintaining the reference after changes to materials is where it gets annoying).
In Cindigo, you can work around that by using the placeholders specified in the label of the texture file selector ($tex01$, $tex02$, $tex03$).
It's lame, but works.
These placeholders will be replaced with the id the texture actually has on rendering.
your ISL code should look like this:
  let
  in
    lerp(
      sample2DTextureVec3($tex01$, uv),
      sample2DTextureVec3($tex02$, uv),
      minCosTheta()
galinette
Post by galinette » Thu Apr 11, 2013 3:28 am
N.G. wrote:YES.
For fresnel, as told before, you can try:
1.0 - pow(1.0 - (2.0/(1.0/maxCosTheta() + 1.0/minCosTheta())), 5.0)
or
1.0 - pow(1.0 - (0.5*(maxCosTheta() + minCosTheta()), 5.0)
However, none is 100% identical to the one used in most softwares, which use the cosineTheta of the halfway vector, which is not available in Indigo (subliminal message to Ono ;) )
If this was available, you would use :
1.0 - pow(1.0 - cosThetaHalfway(), 5.0)
Eclat-Digital Research
http://www.eclat-digital.com
N.G.
Post by N.G. » Thu Apr 11, 2013 3:34 am
Why should I to score a head program codes? need to make everything easier!!
THANK YOU ALL! :D
Post by OnoSendai » Thu Apr 11, 2013 3:36 am
Good idea :)
wlf_alex
Post by wlf_alex » Thu Apr 11, 2013 3:46 am
Thank you guys! You are Superman!
Post by Zom-B » Thu Apr 11, 2013 4:02 am
Thanks for the code galinette, its better then pure minCosTheta().
I attached example of fresnel vs ISL
galinette wrote:1.0 - pow(1.0 - (2.0/(1.0/maxCosTheta() + 1.0/minCosTheta())), 5.0)
or
The bottom example misses a ) ;)
N.G. wrote:Why should I to score a head program codes? need to make everything easier!!
THANK YOU ALL! :D
Its NOT about coding at all here, JUST the knowledge what values to EDIT!!
I also don't understand ISL code at all!!!!
here is the code I used for the example, the bold number is the strength of fresnel, value of 1,75 seems to be a good start.
let
in
lerp(
1.0 - pow(1.0 - (0.5*(maxCosTheta() + minCosTheta())), 1.75)
I attached also a example with value of 3 just to show you the result.
OnoSendai wrote:
galinette wrote:However, none is 100% identical to the one used in most softwares, which use the cosineTheta of the halfway vector, which is not available in Indigo (subliminal message to Ono ;) )
Good idea :)
Would be sweeeeeet!!! :D
Indigo with value o0f 1.75
Indigo with value of 3.0
C4D fresnel
wlf_alex
Post by wlf_alex » Thu Apr 11, 2013 4:31 am
Thanks a lot Zom-B !!!
galinette
Post by galinette » Thu Apr 11, 2013 4:37 am
Zom-B : which refractive index are you using in the C4D shader?
Etienne
