need help with Cinema4D fresnel
How do I mix the materials through a Fresnel map?
- zeitmeister
The C4D fresnel shader isn't supported.
Perhaps you can search this forum about fresnel; there is an effect with ISL you can use.
- wlf_alex
Re: need help with Cinema4D fresnel
Who can show an example of how to use this effect in 4D?
def eval(vec3 pos) vec3 :
lerp(
vec3(0, 0, 0),
vec3(1.0, 1.0, 1.0),
maxCosTheta()
)the both vec3() are the fresnel colors as rgb (1.0=255)
you can now blend your ISL Shader via "ISL Blend Shader" with the desired map or shader of your choice
best regards
C4D R20 Studio
mad-imagery.com
mad-imagery.com
- wlf_alex
Many thanks, Mor4us! This topic really has been confirmed and you will do it again. It's really simple
But now another question. Is it possible to just mix the textures?
regards..
regards..
How to fix error?
why so difficult?
Hi NG,
I think minCosTheta and maxCosTheta cannot be used in a blend shader for physical reasons (it's then easy to break energy conservation). Also, you are using a color shader (returning a RGB vec3) in a blend shader slot (which must return a single number). Both are triggering errors.
So you should not use a blend material for this. Just use a diffuse or phong material, and use the shader in the diffuse channel.
For red/blue just use:
Also, you could use minCosTheta instead of maxCosTheta, the effect will be slightly different.
I personally use 1.0 - pow(1.0 - (2.0/(1.0/maxCosTheta() + 1.0/minCosTheta())), 5.0) as the lerp function
Etienne
lerp(
vec3(1.0, 0, 0),
vec3(0, 0, 1.0),
maxCosTheta() )I personally use 1.0 - pow(1.0 - (2.0/(1.0/maxCosTheta() + 1.0/minCosTheta())), 5.0) as the lerp function
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
how can I mix the two textures then? I'm confused.galinette wrote:Hi NG,
For red/blue just use:Also, you could use minCosTheta instead of maxCosTheta, the effect will be slightly different.Code: Select all
def eval(vec3 pos) vec3 : lerp( vec3(1.0, 0, 0), vec3(0, 0, 1.0), maxCosTheta() )
Etienne
remains impossible to blend the two textures through Fresnel falloff, or error, or the effect is not the same.
exactly!N.G. wrote:remains impossible to blend the two textures through Fresnel falloff, or error, or the effect is not the same.
It's possible, just requires some ISL.
Can you give an example? very needOnoSendai wrote:It's possible, just requires some ISL.
- wlf_alex
+10N.G. wrote:Can you give an example? very needOnoSendai wrote:It's possible, just requires some ISL.
pls-pls-pls !!!
Users browsing this forum: Ahrefs [Bot] and 58 guests
