by fused » Thu Nov 29, 2012 6:14 am
by zeitmeister » Fri Nov 30, 2012 9:03 pm
Thank you fused!
But Indigo doesn't render material previews or in render manager here; C4D R14 and Mac OS X 10.8.2.
Everything worked fine under Cindigo 3.4.16...
could you check that?
by fused » Fri Nov 30, 2012 10:12 pm
zeitmeister wrote:Thank you fused!
Sure, will look into it.
Can you email me the contents of the C4D console window after having tried to render?
Cheers!
by zeitmeister » Fri Nov 30, 2012 10:24 pm
Few minutes...
Sent from my iPhone using Tapatalk
by zeitmeister » Tue Dec 04, 2012 7:22 am
I can't send you any log file, because this error doesn't occur in any... neither C4D console nor apple system log...
forgeflow
by forgeflow » Tue Dec 04, 2012 3:14 pm
Same issue here too. Indigo Render used to render directly in the Cinema 4D R13 application. This doesn't, and there are no material previews - just black spheres. Something is wrong.
Edit - also nothing in the log files here.
forgeflow
by forgeflow » Wed Dec 05, 2012 10:38 am
Any idea of what broke in this version? The only rendering option available with this is to "export" to Indigo and render there, which is not a really attractive workflow. And the lack of material preview makes material editing nearly impossible. I'm going back to the previous version, even with it's crashes, because at least it worked.
by fused » Thu Dec 06, 2012 1:12 am
I was ill the last two days so I couldn't reply.
Sorry about this issue, I will look into it immediately. I would still like to see the C4D log, tho. What I am interested in is if it says that Indigo was initialised properly or not, right after C4D startup.
Regards,
Yves
forgeflow
by forgeflow » Thu Dec 06, 2012 2:26 am
Ah, right you are.... it's not initializing properly.
Can't seem to cut and past the code, so here's a screenshot:
by fused » Thu Dec 06, 2012 2:58 am
forgeflow wrote:Ah, right you are.... it's not initializing properly.
