hair and more
hair and more
how can i render hair or eyelashes or pretty anything that needs alpha/transparency channels? obviously i need the diffuse, alpha/transparency channel for the textures. but when i pick the diffuse option there is no option for alpha or transparency...
- PureSpider
Re: hair and more
Use the blend channel and don't use another material to blend, then you will get transparency
Re: hair and more
fast response. wow thanks
so use my texture for teh diffuse adn turn on the blend channel?
- PureSpider
Re: hair and more
working good now.. im a fan of Indigo now. might be giving Vray the boot LOL
Re: hair and more
If you use a PNG with alpha, not in a separate channel, but simply a texture with transparency, then Indigo uses thatindia wrote:but when i pick the diffuse option there is no option for alpha or transparency...
give it a try
Re: hair and more
ah that workedZom-B wrote:If you use a PNG with alpha, not in a separate channel, but simply a texture with transparency, then Indigo uses thatindia wrote:but when i pick the diffuse option there is no option for alpha or transparency...
give it a try
