Movie-Export works, but i become only one pos. from the Cam
12 posts • Page 1 of 1
Frank Schroer
Post by Frank Schroer » Fri May 20, 2011 2:38 am
Hello
Export the movie from C4D R12 igs all data is written correctly.
When you calculate it seems only a fixed camera position to write to all images. In C4D
but it is a real camera-carriers. There is only one movie as a still image with the
Number of frames out. Can any one help me
Hallo
beim Film exportieren aus C4D R12 werden alle igs-Daten richtig geschrieben.
Beim berechnen scheint er aber nur eine feste Kamera-Position auf alle Bilder zu schreiben. Im C4D
ist es aber eine richtige Kamera-Fahrt. Es kommt aber nur ein Film als Standbild mit entsprechenden
Anzahl der Frames heraus. Kann mir einer helfen
Regards,
Frank
http://www.cycot.de
Re: Movie-Export works, but i become only one pos. from the
Post by Zom-B » Fri May 20, 2011 2:49 am
Hey Frank,
I did some animation using Cindigo too, but never had this issue...
Did ya double checked if camera is also active before exporting?
I have no idea if the Camera switching via the "scene Object" is supported
in Cindigo if you use one...
If you still have the issue after double checking, please copy the camera animation into a empty scene and upload it, so we can check it out! :)
Frank Schroer
Post by Frank Schroer » Fri May 20, 2011 2:58 am
Yes, I've checked everything! Camera is active and also the frame range. I've also take a
Cube in the scene moves to the test - Is not. He always writes the first frame and
seems to be copied to any other. hmm!
Ja, ich hab alles gecheckt! Kamera ist aktiv und auch der Framebereich. Ich hab auch mal einen
Würfel zum Test in der Scene bewegt-- Geht auch nicht. Er schreibt immer den ersten Frame und
scheint den auf alle anderen zu kopieren. hmm!
Regards,
Frank
http://www.cycot.de
Post by fused » Fri May 20, 2011 3:00 am
Zom-B wrote:If you still have the issue after double checking, please copy the camera animation into a empty scene and upload it, so we can check it out! :)
Hi Frank,
if the issue still remains after finding the issue, please do that.
Thank you!
Frank Schroer
Post by Frank Schroer » Fri May 20, 2011 3:10 am
OK, Here are the C4D-File with the wrong Movie-Export...
Indigo Filmtest.zip
(1.77 MiB) Downloaded 300 times
Regards,
Frank
http://www.cycot.de
Post by Zom-B » Fri May 20, 2011 3:41 am
For me the Export works fine, here is the proof of first & last image rendered:
Are you using the MAc version? Maybe its broken there... I'm on a PC.
To render this bunch of IGS files use the following script: http://www.indigorenderer.com/forum/vie ... =7&t=10247
Frank Schroer
Post by Frank Schroer » Fri May 20, 2011 9:07 pm
Hi Zoom_B
Thank you for your efforts - I am working on WIN 7 64 bit.
Yes, I have calculated the same with the IGS-Script Works, But the mistake that all
IGS files are the same is still there. I'm now 2 days on it and let it be wasted
now. Unfortunately, I have thus lost a large customer, which will now buy Maxwell. The
Client but found it with the script calculation, an unreasonable demand, and as I have Him
fully give right. Enter in DOS windows to have to do is simply not up to date
and to provide no more! I'll look at the Indigo3 this regard. If as this
Export error is still going, I look around me for something else. Then the Indigo
simply no longer competitive!
Greetings
Frank
Hi Zoom_B
Danke für deine Bemühungen-- Ich arbeite auf WIN 7 64 Bit.
Ja, ich hab das auch mit den IGS-Skript berechnet- Funktioniert auch- Aber der Fehler,, das alle
IGS Dateien gleich sind ist immer noch da. Ich hab jetzt 2 Tage daran verschwendet und lasse es
jetzt. Leider habe ich dadurch einen großen Kunden verloren, der jetzt Maxwell kaufen wird. Das
Kunde fand es aber auch mit der Skript-Berechnung eine Zumutung, und da muß ich Ihm
uneingeschränkt recht geben. In DOS-Fenstern eingeben zu müssen ist einfach nicht mehr zeitgemäß
und nicht mehr zu vermitteln! Ich werde mir den Indigo3 diesbezüglich anschauen. Wenn da dieser
Export-Fehler immer noch ist, werde ich mich nach was anderem umschauen. Dann ist der Indigo
einfach nicht mehr Konkurrenzfähig!
Gruß
Frank
Regards,
Frank
http://www.cycot.de
Post by Zom-B » Fri May 20, 2011 9:39 pm
Hey Frank,
I can understand your disappointment, animation support sucks atm with Indigo 2.
But nether less I'm still convinced that animation output works in Cindigo as my proof
Screens show, no tweaking, no adjusting... just out of the box!
I'm on Vista 64 running latest R12...
Try to delete the actual, and install latest Cindigo: http://www.indigorenderer.com/forum/vie ... 10&t=10674
I've done a lot of beta testing for Cindigo and am very interested about any bugs, so excuse me to
hock on this.
So my last question here is your C4D version and a request to zip and upload the exported files (together with meshes folder). Maybe there are some differences in the frames but not related to cam + cube animation... I'll investigate :)
**EDIT**
Now I found your specs on the bottom of your post -.-
Is this right that you still use the initial release C4D 12 without any updates applied??? why is that so?
If you also use the OLD R12 Beta Cindigo we found the reason for your issues :)
Frank Schroer
Post by Frank Schroer » Fri May 20, 2011 10:57 pm
Hi Zoom_B
OK, that was the right note! Thank you! Cindigo-2.6.2 it works. Thanks
I overlooked that there is already a new version of Cindigo. But the problem with the
Script remains - and the customer is gone :-(
Greetings
Frank
Hi Zoom_B
OK, das war der richtige Hinweis! Danke! Cindigo 2.6.2- es Funktioniert. Danke
Ich habe übersehen, das es schon eine neue Version vom Cindigo gibt. Aber das Problem mit dem
Skript bleibt-- Und der Kunde ist auch weg :-(
Gruß
Frank
Regards,
Frank
http://www.cycot.de
Post by fused » Fri May 20, 2011 11:12 pm
Frank Schroer wrote:Hi Zoom_B
Greetings
Frank
Hi Zoom_B
Gruß
Frank
Hi Frank,
das ist echt schade das zu hören, besonders da die 3.0 version eine render queue eingbaut hat, die mehrere igs dateien nacheinander rendert.
Ist auch alles schon in der Cindigo 3.0 Beta version implementiert.... warte nur auf das "go" :)
@Zom-B: riesen dank für deine Mühen. Bist unersetzbar :)
Post by Zom-B » Fri May 20, 2011 11:14 pm
Glad that your issue was fixed by the latest Version!
I'm sure Glare worked out something about this for the v3 release,
the actual Demo Video only shows Real Time controls with GPU rendering
it can't be that this will be the only new features in the upcoming version!
As always its easy to complain later, after the damage is done Frank!
If there are issues, also regarding (missing) features or bugs then tell about it,
contact Glare directly if needed!
You are a paying customer and the Glare team will take your ideas and critic serious for sure!
Frank Schroer
Post by Frank Schroer » Sat May 21, 2011 12:15 am
Hi
The problem of key frame exports do not just since yesterday. It should be clear to any manufacturer that when you change over six months in a deplorable state of affairs nothing, eventually losing to the competitors! And that has now entered!
I hope I continue with the version of Indigo 3 can still convince our prospects better than before.
Greetings, Frank
Hi
Das Problem des Keyframe Exports existiert nicht erst seit gestern. Es sollte jedem Hersteller klar sein, das wenn man über ein halbes Jahr an einem Mißstand nichts ändert, irgendwann gegen den Wettbewerber verliert! Und das ist jetzt eingetreten!
Ich hoffe, das ich in Zukunft mit der Version Indigo 3 unsere Interessenten noch besser überzeugen kann als bisher.
Gruß, Frank
Regards,
Frank
http://www.cycot.de
Users browsing this forum: No registered users and 46 guests
