I have problem whit Cindigo
jesto
Post by jesto » Mon Dec 13, 2010 11:42 am
After install Cindigo 2.4.13 in C4D i can´t view the plugin.
Re: I have problem whit Cindigo
Post by Zom-B » Mon Dec 13, 2010 8:11 pm
Some more specs would help a lot as you could imagine my friend :wink:
Mac or PC, C4D version?
- Take care that you downloaded the right PlugIn Version for your C4D version!
- C4D 12 isn't supported atm!
- Does both version don't get recognized: 32 and 64bit?
jesto
Post by jesto » Mon Jan 24, 2011 7:25 pm
Zom-B wrote:Some more specs would help a lot as you could imagine my friend :wink:
i use C4D 11.5 64Bits and intalled Cindigo of 64Bits on my Mac
Post by zeitmeister » Tue Jan 25, 2011 12:24 am
No problems here...
did you put the folder named "Cindigo 2.4.13" into you C4D plugins-folder?
jesto
Post by jesto » Tue Jan 25, 2011 1:39 am
zeitmeister wrote:No problems here...
Yes the Plug in Cindigo is intalled on this folder, now y have problem when try to render.
Post by fused » Tue Jan 25, 2011 3:04 am
Hey jesto,
I have heared about this issue before, but could never reproduce it myself.
Does that also happen when running C4D in 32 bit mode?
jesto
Post by jesto » Tue Jan 25, 2011 5:13 am
Hey jesto,
The problem continue on C4D mode 32Bits
Post by fused » Tue Jan 25, 2011 6:33 am
Thanks.
Also, what is the exact version number of your C4D?
jesto
Post by jesto » Tue Jan 25, 2011 7:39 am
C4D 11.5
Snow Leopard 10.6
Post by Zom-B » Tue Jan 25, 2011 7:49 am
Maybe fused was talking about your detailed C4D version number!?
including Patch info etc, found under Help > Info
Post by fused » Tue Jan 25, 2011 9:25 am
Zom-B wrote:Maybe fused was talking about your detailed C4D version number!?
Yes, exactly, this one, thanks ZomB :)
ColeHarris
Post by ColeHarris » Thu Jan 27, 2011 9:59 am
Same problem here, at least I think so. Whenever I start a cindigo render in Cinema 4D a box pops up saying exporting and then a dialogue pops up saying that cinema 4d has unexpectedly quite even though the application is still open, and Indigo never opens. I'm using version 11.514 build RC20476 Thanks
Post by Zom-B » Thu Jan 27, 2011 10:55 am
Hey Harris,
Cindigo outputs all informations during export in the C4D console,
so you can see where exactly cindigo crashes C4D.
If it crashes after "starting Indigo" you could maybe have a working igs
exported in your folder that can be rendered by manually opening it in Indigo.
Post by fused » Thu Jan 27, 2011 12:25 pm
ColeHarris,
are you using a mac? Can you post the osx crash report info or mail it to support, at, indigorenderer, dot, com?
I will try to fix these issues as fast as possible for the 2.6.1 mac version of cindigo.
ColeHarris
Post by ColeHarris » Fri Jan 28, 2011 7:20 am
Thanks guys, apparently it was able to export an igs before crashing but when I open it none of images I have applied to any materials render so it must not be exporting those. I attached the OSX crash report for cinema, the Cinema console showed no errors everything appears to export and it says that it has launched Indigo but Indigo never opens. Thanks for the help!
Crash Report Cinema.pdf
(48.97 KiB) Downloaded 410 times
Users browsing this forum: No registered users and 57 guests
