Indigo 0.9 test 2
Indigo 0.9 test 2
Post by OnoSendai » Thu Jul 19, 2007 7:40 pm
This version should be a little bit faster than test 1.
It also only uses the SSE1 enhanced x86 instruction set instead of SS2.
http://www.indigorenderer.com/montecarl ... _test2.zip
Changelog:
0.9 test 2
* added --ptest option (performance test)
* fixed crash at tree build time on degenerate triangles
* updated diffuse_transmitter material to use 'albedo_spectrum' instead of 'colour' like the diffuse material.
* sped up splatting a little
* misc performance increases.
0.9 test 1
* added indigo_console build
* moved OpenEXR to dlls
* made image saves less likely to get corrupted (saves to temp image then moves to final path)
* added shutter_open_duration (aka shutter speed)
* made diffuse material use 'albedo_spectrum' instead of 'colour'
* made phong material use 'diffuse_albedo_spectrum' instead of 'diffuse'
* rgb_spectrum now requires the 'gamma' element. Use 2.2 as default.
* added checks for SSE and SSE2
* fixed bug with light sampling
* fixed material binding to spheres
* added atmosphere medium type
* added extra_atmospheric parameter to sky_light
* added ray_origin_nudge_distance parameter to inifile
* messed around with refraction code a little
* fixed .bmps loading upside down
* added exit portals
* added textured emitters
SmartDen
Post by SmartDen » Thu Jul 19, 2007 7:54 pm
Thanx Ono! I will update the Blendigo and test ist immediately!
BTW What is performance test doing?
Post by OnoSendai » Thu Jul 19, 2007 8:04 pm
--ptest just turns off the image display and image saving, and sets the halt time to 30s.
SURFiNG
Post by SURFiNG » Thu Jul 19, 2007 8:05 pm
yessssssssssss
mrCarnivore
Post by mrCarnivore » Thu Jul 19, 2007 8:17 pm
Did you do any bugfixes from 0.9 test 1 to 0.9 test 2?
There are surely some bugs in 0.9 test 1. I had some problems with specular materials / sss. Didn't test extensively to pinpoint the bug, due to lack of time. But some other guys in this forum had the same errors...
Post by suvakas » Thu Jul 19, 2007 9:07 pm
Great build !
Works good so far. 8)
Marcofly
Post by Marcofly » Thu Jul 19, 2007 9:12 pm
first test..
it is *A LOT* faster!!
thank you very much, Ono!!!
Marco
SURFiNG
Post by SURFiNG » Thu Jul 19, 2007 9:15 pm
marco, have you got MSN? I have some questions for you, maybe you can help me!
Edit: Nevermind, SOLVED :lol:
drBouvierLeduc
Post by drBouvierLeduc » Thu Jul 19, 2007 10:14 pm
Great, with this release, indigo 0.9 doesn't crash anymore ! (couldn't render a single scene with test1).
And with exit portals, oh my !
Post by Kram1032 » Thu Jul 19, 2007 10:29 pm
:shock: Faster and SSE compatible? great!
so, it basically is slight bug-fixing and speedgaining relase, with better compatibility? :D
manuel
Post by manuel » Thu Jul 19, 2007 10:34 pm
wohoo, now my old scenes work again! :o)
exit portals iam coming hehe
big thx ono!
deltaepsylon
Post by deltaepsylon » Thu Jul 19, 2007 11:25 pm
w00t ware! now all i gotta do is find the new blendigo...
Stur
Post by Stur » Thu Jul 19, 2007 11:54 pm
Thx for this release.
Am I doing something wrong, or exit portals work only with sun light ? My pictures stays black if I use a mesh emitter outside of my room.
(The reason I used a mesh emitter instead of a sun is that I wanted to simulate a blueish moon light like we often see with night scenes in movies)
Post by Kram1032 » Fri Jul 20, 2007 12:00 am
bluish moonlight can be tonemapped, I'd say^^
afecelis
Post by afecelis » Fri Jul 20, 2007 12:26 am
Thanks a lot Master Ono! :D way to go!
