Indigo Renderer 3.6.7 Beta Release
5 posts • Page 1 of 1
Post by OnoSendai » Sun Feb 17, 2013 2:25 am
The big change in this release is the reworking of foreground alpha rendering.
To try it out, tick 'foreground alpha' in the render mode settings.
If you then save out a render (e.g. with the 'Save Image' button), the foreground will have alpha one, and the background (sky etc..) will have alpha zero. This should allow simple and high-quality compositing with alternative background images.
There have been some major internal changes to make this possible, so there are likely some bugs to iron out.
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.6.7_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.6.7_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.6.7.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.6.7.tar.gz
IndigoRenderer3.6.7.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.6.7_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.6.7_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.6.7.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.6.7.tar.gz
IndigoRT3.6.7.dmg
Changelog:
3.6.7
* Made render_foreground_alpha back into a checkbox instead of a render mode. Foreground alpha now sets the alpha channel of saved images directly.
* Fixed loading of coating and double-sided thin materials.
* Made MatDB items display created-by username.
* Fixed loading of PIGS files.
* Fixed: GUI gets put in weird state after opening a scene with an error.
* Fixed crash when opening images in Indigo RT.
* Fixed radial splatter normalisation.
* Added a 'reload image' button to texture editor window.
Post by zeitmeister » Sun Feb 17, 2013 2:38 am
Fantastic, thank you!
cotty
Re: Indigo Renderer 3.6.7 Beta Release
Post by cotty » Sun Feb 17, 2013 2:49 am
I've tried to use the foreground alpha and get no preview (the saved file is empty too), what did I do wrong?
http://screenr.com/dCZ7
Thank you!
Edit: Oh, I tried without GPU and it works, perhaps there should be a warning, auto disabling of GPU or something like this.
Nice update and valuable new function! (@ Whaat: we NEED that option in SkIndigo ;-) )
Mor4us
Post by Mor4us » Wed Feb 27, 2013 12:46 am
I hit on some problems when fooling around with network rendering:
- file throughput to a Windows master is ridiculously slow, though gigabit network
- "wait for slave frames" doesn't stop client rendering after last frame
- there's no kind of remote control of clients used, start/stop manually
- no way to force client uploading latest render progress
fe: stopping master causes loose of latest slave renderprogress
- maybe a countdown in network rendering tab (master) that shows time to next img upload by each client
best regards
Markus
Post by OnoSendai » Wed Feb 27, 2013 5:18 am
Mor4us wrote: - file throughput to a Windows master is ridiculously slow, though gigabit network
This may be improved in the next release.
Users browsing this forum: Majestic-12 [Bot] and 7 guests
