Indigo Renderer 3.6.4 Beta Release
Post by OnoSendai » Mon Jan 07, 2013 3:55 am
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.6.4_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.6.4_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.6.4.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.6.4.tar.gz
IndigoRenderer3.6.4.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.6.4_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.6.4_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.6.4.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.6.4.tar.gz
IndigoRT3.6.4.dmg
Changelog:
3.6.4
* Fixed spherical camera so that the image tiles perfectly.
* Added Voronoi basis types for fbm() and multifractal()
* Fixed slow subdiv + displacement build problem in 3.6.3.
* Print out the mesh name while doing subdiv + displacement.
Re: Indigo Renderer 3.6.4 Beta Release
Post by Zom-B » Mon Jan 07, 2013 5:20 am
thanks for the update :)
I can now confirm the speedup in subdiv inside a simple scene with 6 steps:
3.6.2: 12.7 sec
3.6.4: 9.4sec
Speedups are always sweet :)
Post by OnoSendai » Mon Jan 07, 2013 5:45 am
Zom-B wrote:thanks for the update :)
3.6.2: 12.7 sec
3.6.4: 9.4sec
Great.
Displacement should be a lot faster as well.
dag
Post by dag » Mon Jan 07, 2013 5:52 am
Spherical tiles ok now, but there's vertical lines that are brighter on both edges.
left edge
Post by CTZn » Tue Jan 08, 2013 1:12 am
Good job with the displacement speed, it feels alright. The new numeric fields are just perfect.
A few notes, granted that the features are in beta:
- albedo shaders must be gamma corrected; it might be better if that was managed at a lower level than ISL.
- displacement seems to use swapped axis to evaluate posOS(), see attached.
- is the usage of posOS() possible for bump mapping ?
- 2d pendants of the multifractal, and 3d voronoi please :D
To be honest I'm a bit overhelmed by the expanding noises set, furthermore I came to forget about their develloped, native implementation.
But once it's complete I'll be punished and will have to get something out of that ☺
bug orthogonal shaders.pigs
(156.97 KiB) Downloaded 793 times
Post by OnoSendai » Tue Jan 08, 2013 1:25 am
CTZn wrote:Good job with the displacement speed, it feels alright. The new numeric fields are just perfect.
"albedo shaders must be gamma corrected;": According to whom? Why?
"displacement seems to use swapped axis to evaluate posOS(), see attached" Which axis are you referring to?
" is the usage of posOS() possible for bump mapping ?": not yet.
"2d pendants of the multifractal," : 'pendants'? What do you mean by that?
"3d voronoi": Can add, will be quite slow tho :)
Post by CTZn » Tue Jan 08, 2013 1:39 am
According to the sole me of course, I'll have to double check about that.
Z (right hand swap) ? In the attached scene, the displaced veins are running horizontally and vertically in the albedo while using the same-ish code. I was wondering if you were trying to get me into matrices one more time...
* ok
* pendant: version, sorry. Blame my globish.
* ok
Post by OnoSendai » Tue Jan 08, 2013 1:59 am
dag wrote:Spherical tiles ok now, but there's vertical lines that are brighter on both edges.
What render mode are you using, single dir or bidir?
Post by OnoSendai » Tue Jan 08, 2013 2:26 am
Better yet, can you send me the (simplified) scene?
FakeShamus
Post by FakeShamus » Wed Jan 09, 2013 6:52 am
hey Ono,
I'm not seeing the speed-up on subdivision and displacement on the new build. I'm using theOSX version.
on the "infinite head" scene I've been playing with, for example, 3.6.2 blazes through 4 levels of subdiv (generates 1,000,000 quads in 1.6 seconds), but 3.6.4 takes several minutes and then crashes on the last subdiv level using the same scene.
noldo
Post by noldo » Wed Jan 09, 2013 6:57 am
With gpu acceleration, the sun light not working. (Skindigo + indigo rt 64 bit)
Post by OnoSendai » Wed Jan 09, 2013 6:58 am
FakeShamus wrote:hey Ono,
Ok, thanks for report. The performance is quite dependent on the compiler and libraries. Will fix.
dag
Post by dag » Wed Jan 09, 2013 11:39 am
Happens only with bidir.
room.pigs
(11.32 KiB) Downloaded 727 times
Post by Pibuz » Sat Jan 12, 2013 4:50 am
Sorry, small request (too silly to open a new topic): would it be possible to make invisible a EXR map as a checkbox in the Indigo GUI?
Post by Zom-B » Sat Jan 12, 2013 5:05 am
Something like a integrated alpha of the BG in the actual rendering, right?
