Indigo Renderer 3.2.11
6 posts • Page 1 of 1
Post by fused » Thu Apr 19, 2012 11:51 pm
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.2.11_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.2.11_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.2.11.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.2.11.tar.gz
IndigoRenderer3.2.11.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.2.11_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.2.11_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.2.11.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.2.11.tar.gz
IndigoRT3.2.11.dmg
Changelog:
3.2.11
* Added updated Manual.
* Made some improvements to the tracing precision.
* Removed support for .3ds file format.
* Fixed picking and painting materials in free mode with reduced resolution.
* Updated bundled C4D exporter to Indigo for Cinema 4D 3.2.10.
snorky
Re: Indigo Renderer 3.2.11
Post by snorky » Fri Apr 20, 2012 1:54 am
the reason?
Post by fused » Fri Apr 20, 2012 2:05 am
the reason?
The library we were using is not maintained anymore and is rather buggy.
tar_gniK
3D Software: 3ds Max
Post by tar_gniK » Fri Apr 20, 2012 5:25 am
What is the procedure for an image update? Any help would be appreciated, because I am really confused here.
In previous versions, making a change to the tonemapping, ISO, EV would result in an instant image update -- the progress bar would reset and calculate a new time for the next auto image update.
Now, changes in the tonemapping are reflected in the image, but the progress bar does not reset.
Furthermore, with the auto image update, when Indigo saves the image to disk, the changes made to the tonemapping and EV/ISO values are not reflected in the autosaved image -- the values used from the exporter (Maxigo) are saved instead. This really caught me out -- yesterday, my PC blue screened overnight.
I thought that I would be able to salvage the render by going to the auto-save folder. But the tonemapping changes made were not saved in the image.
Any help please? I am using 3.2.10.
Post by OnoSendai » Fri Apr 20, 2012 5:31 am
tar_gniK wrote:What is the procedure for an image update? Any help would be appreciated, because I am really confused here.
Hi tar_gniK, if you saved out an IGI, you can resume from the IGI, then change the tonemapping as you wish.
tar_gniK
Post by tar_gniK » Fri Apr 20, 2012 5:57 am
Ok, understood. Thank you.
