- 3D Software: SketchUp
by Pibuz » Tue Feb 07, 2012 6:37 am
Hi guys!
I'm reporting a small bug with current version and Exit Portals: even if the render is NOT using the GPU (so NO plain PT), the image is completely black when I use the new sky model.
Everything is ok if with same settings I enable the former sky model.
Using Indigo 3.2.7, SkIndigo 3.2.5 and nVidia drivers 276.42.
ENSLAVER
by ENSLAVER » Tue Feb 07, 2012 1:56 pm
Pibuz wrote:Hi guys!
It does work for me with the new sky model, though in some modes (PT, PT+GPU, PT+MLT) it exhibits odd behaviour. Light comes out both sides of the portal (not just the direction of the normal) and in pure PT or PT+GPU it is really slow to converge.
It should work fine in a BiDir mode Pibuz?
by lycium » Tue Feb 07, 2012 2:24 pm
This is a confirmed bug and we're looking into it; thx for reporting Pibuz!
by Pibuz » Tue Feb 07, 2012 8:22 pm
In my experience, the image renders pure black if PT (or GPU) is enabled, even if the sample rate actually goes up. The same error shows up using BiDir too: the problem here seem to be generated by the combined use of EPs and new sky model; the different behaviours may depend on something related to the video card..
by StompinTom » Tue Feb 07, 2012 9:54 pm
Would it be possible to finally kill the 'material index out of bounds' error? If an object from Blender has a material assigned that is not used for any of its faces, then Indigo won't render it. Frustrating for large, imported scenes.
Also, any updates on the instancing + precision issue?
Otherwise, will test this out once I get a bit of time!
by lycium » Tue Feb 07, 2012 11:25 pm
No change on the instancing, since generally we don't see any problem with it; if you could send us a scene showing such precision issues I'll definitely look into it though.
by OnoSendai » Sat Feb 11, 2012 3:26 am
Thanks for bug report Pibuz. Fixed for 3.2.8.
Users browsing this forum: No registered users and 82 guests
