Indigo Renderer and Indigo RT 3.0.12
Post by fused » Sat Jul 02, 2011 2:54 am
This is a Beta release.
Indigo Renderer for Windows 32-bit:
IndigoRenderer_3.0.12_Setup.exe
Indigo Renderer for Windows 64-bit:
IndigoRenderer_x64_3.0.12_Setup.exe
Indigo RT for Windows 32-bit:
IndigoRT_3.0.12_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.0.12_Setup.exe
Indigo Renderer for Mac:
IndigoRenderer3.0.12_CPU_ONLY.dmg (OSX 10.5, CPU only)
IndigoRenderer3.0.12_CUDA_OPENCL.dmg (for OSX 10.6 and Nvidia GPUs)
IndigoRenderer3.0.12_OPENCL.dmg (for OSX 10.6)
Indigo RT for Mac:
IndigoRT3.0.12_CPU_ONLY.dmg (OSX 10.5, CPU only)
IndigoRT3.0.12_CUDA_OPENCL.dmg (for OSX 10.6 and Nvidia GPUs)
IndigoRT3.0.12_OPENCL.dmg (for OSX 10.6)
Linux builds will follow.
Changelog:
3.0.12
* Added Glass Acceleration for path tracing (also works with GPU mode).
* Added console build for Indigo RT.
* Fixed crash with OpenGL drawing and camera movement.
* Fixed operator overloading issues in some cases in ISL, added gt, lt, eq etc.. for floats.
3.0.11
* Added voronoi and gridNoise ISL functions.
* Added uninstaller.
Some comparison images for the new PT glass acceleration.
Both rendered on 2 machines for 5 minutes with GPU mode.
Glass acceleration on:
Glass acceleration off:
Re: Indigo Renderer and Indigo RT 3.0.12
Post by StompinTom » Sat Jul 02, 2011 3:37 am
Eesh that's very good news!
Post by pixie » Sat Jul 02, 2011 3:51 am
PT has become a Monster mode!!
Xaon
Post by Xaon » Sat Jul 02, 2011 7:07 am
My PC is blocked with the launching of one returned, obliged to start again with the button…
Windows 7 32 bits
Athlon 6000+ to 3.0 GHz
HD Radeon 5770 1Go
Is it what the concern?
Post by CTZn » Sat Jul 02, 2011 9:54 am
"returned" = render ;)
1: does it happen every time ?
2: does it happen with 3.0.10 ?
3: after this error and before launching another render please copy the content of log.txt (found in C:\Users\*username*\AppData\Roaming\Indigo Renderer) and paste it here.
Post by fused » Sat Jul 02, 2011 1:24 pm
Added builds for Mac OSX 10.5 and 10.6 to first post :)
ENSLAVER
Post by ENSLAVER » Sat Jul 02, 2011 2:25 pm
Is there a downside to leaving glass accel on all the time? It's awesome.
snorky
Post by snorky » Sat Jul 02, 2011 6:09 pm
fused wrote:This is a Beta release.
Pause button don't work for me.
I press pause, move camera and render restart automagically.
Xaon
Post by Xaon » Sat Jul 02, 2011 7:36 pm
Je vais parler en français ça sera plus simple.
Dès que je lance un rendu via Sketchup en cliquant sur le bouton, Indigo s'ouvre, ça tourne 2 ou 3 secondes et là mon PC se fige entièrement. Là souris ne bouge plus je peux rien faire. Je dois redémarrer à l'arrache avec le bouton... :/
Ca le fait à chaque fois.
P.S : avec la version 3.0.12, je n'avais pas de soucis avant.
snorky
Post by snorky » Sat Jul 02, 2011 10:33 pm
Xaon wrote:Je vais parler en français ça sera plus simple.
S'il vous plaît dites des composants de votre ordinateur...
Xaon
Post by Xaon » Sat Jul 02, 2011 11:24 pm
Je tourne sous Windows 7 32 bits avec un Athlon 6000+ un HD Radeon 5770 1Go et 2 Go
de RAM à 800 MHz.
J'ai rien dans le fichier log :
=============================Indigo Started===============================
Fri Jul 01 21:01:56 2011
Edit : En lançant uniquement Indigo sans rendu je n'ai aucun soucis.
snorky
Post by snorky » Sun Jul 03, 2011 12:08 am
Xaon wrote:Je tourne sous Windows 7 32 bits avec un Athlon 6000+ un HD Radeon 5770 1Go et 2 Go
de RAM à 800 MHz.
openCL? oui ou non? avez-vous essayé avec le mode de render CPU?
vous avez installé la dernière driver?
Xaon
Post by Xaon » Sun Jul 03, 2011 12:21 am
Oui avec la version 3.0 j'utilisais l'accélération GPU et je n'avais aucun problème.
Là le soucis c'est que je ne peux pas la désactiver, car en lançant Indigo seul je n'ai pas accès aux options... :/
Les pilotes de ma carte graphique sont à jour (11.6).
Je vais essayer de repasser à la première version d'Indigo 3.0 (j'ai gardé le fichier), je vous tiens au courant (c'est pas forcément lui qui fige mon PC, mais peut-être un logiciel installé récemment).
Edit : Avec la version 3.0 de base je n'ai aucun soucis.
Post by CTZn » Sun Jul 03, 2011 1:34 am
Xaon wrote:Oui avec la version 3.0 j'utilisais l'accélération GPU et je n'avais aucun problème.
Normalement tu as accès aux options après avoir chargé la scène et avant de démarrer le rendu.
Je transmets ton rapport, merci.
Post by fused » Sun Jul 03, 2011 1:41 am
What is the problem?
Translation please? :)
Users browsing this forum: No registered users and 71 guests
