Indigo 0.8 test 1
Thank you very much for this summarised explanation!manitwo wrote:all modes should give the exact same image after a given time. So every mode is physical accurate. The difference between those modes is how the noise converges. Some modes are faster, some slower for different things.
- MLT is good for indirect light, glass and caustics but not so good for direct light. Generally the noise is kind of "dirty-patchy-nonuniform".
- PathTracing is good for direct light but needs longer for indirect light, glass and caustics. The noise is uniform.
- Hybrid is a combination of MLT and PT. Hybrid uses PT for direct light and MLT for indirect light, glass and caustics. Hybrid combines the strenghts of MLT and PT. If Hybrid is enabled the Metropolis option is ignored.
- Bidir can be combined with MLT or PT or Hybrid. Bidir makes noise in scenes with indirect light, glass and caustics clear faster.
In indigo 0.8t1 bidir is causing black-image problems but keep in mind that the actual version is a test release! - so don't hesitate
- rQMC is (afaik) a more efficient way of sampling which also makes the noise clear faster (some scenes benefit a bit, others a lot). As a side effect there might be noise-"patterns" in the first seconds of rendering. rQMC is enabled since 0.8 - you cant turn it off - but why should you?
once again:
Possible Combinations:
- MLT Mode: ("Metropolis"-true)
- Pathtracing Mode: ("Metropolis"-false)
- Hybrid Mode: ("Hybrid"-true)
- Bidir MLT Mode: ("Metropolis"-true, "Bidir"-true)
- Bidir Pathtracing: ("Metropolis"-false, "Bidir"-true)
- Bidir Hybrid Mode: ("Hybrid"-true, "Bidir"-true)
The last two modes are recommend.
Hope this helps!
It also should enter the Indigo manual and the Wiki, in my opinion.
Just dled the new release and I must say it rocks. It has less of the memory problems/crashes the 07 release had. I keep on working on indigoworld now. Doing a test render of about 1M tris atm.
(for those of you that dont know what indigoworld is here is an old image)
http://www2.indigorenderer.com/joomla/i ... emId=10360
Sorry maintwo... but I not understand.
Bidir is usefull for direct light but the noise is more present
Metropolis is useull for indirect light
Hybrid ignore the metropolis and use bidir or pt.
the combination of bidir and metropolis is a good choise?
If we use only bidir or only metropolis is phisically correct... ?
the images procuduced by Bidir or Metropolis or Hybrid
method are different...
so wha is the best situation for a phisically correct solution?
Ono can you help us?
Users browsing this forum: No registered users and 78 guests
