Indigo Renderer 4 public beta
Originalplan®
Post by Originalplan® » Thu Jun 16, 2016 12:39 am
Found a more serious bug: v4.37 C4d>Indigo>igi>Import igi to resume. (i know the resume does not function yet )
So i save out a scene 1 in igi. Load another scene (2) save it out as .igi i quit Indigo.
Restart Indigo load in scene1.igi and as i hit render..scene1 & SCNENE2 are beginning to render!
(Like scene2 was still in the memory) < even if i quit Indigo & restart it.
Very weird bug, please have a look @memory things in igi format and also the small interactive window for materials inside Indigo, i mentioned before that the material preview keeps running after scene is closed. (not a big thing but worth a look )
Hope this info helps.
Zalevskiy
Post by Zalevskiy » Thu Jun 16, 2016 9:12 pm
Post by Zom-B » Thu Jun 16, 2016 10:19 pm
Thanks for the report Zalevskiy.
I created a ticket in the bugtracker for this issue, but the material seems fishy too...
To make this material work you'll need to unpack the pigm and edit the igm file inside to have all the wavelength be:
						<start_wavelength>4e-7</start_wavelength>
						<end_wavelength>7e-7</end_wavelength>
Anyway, the material is slow has some design flaws and is maybe not worth fiddling around with it.
Post by pixie » Thu Jun 16, 2016 10:50 pm
The gpu struggles with isl, and when used with coating present different results of CPU.
Originalplan®
Post by Originalplan® » Fri Jun 17, 2016 1:37 am
OSX [ performace killer ] : Inside v4.37 when loading a scene (from c4d 1080p rez) and changing the resolution inside Indigo to a smaller on ( 800x600 ) leads to an unresponsive freezed up Indigo when changing from CPU to OpenCL. Indigo became so unresposive that i had to restart the system.
Maybe worth a look.
Post by OnoSendai » Sat Jun 18, 2016 12:30 am
dakiru
Post by dakiru » Sat Jun 18, 2016 7:32 am
pixie wrote:I've got both gfx boards on Linux! :D Still I'm quite baffled just how fast it is on OSX. Linux seems to be the best responsive system.
Desktop responsiveness depends quite a bit on the CPU scheduler that is used. Check this out.
Edit: and this.
Post by pixie » Sat Jun 18, 2016 8:03 am
Edit: and this.
And in this case perhaps the gpu scheduler
Post by OnoSendai » Wed Jun 22, 2016 1:03 am
pixie wrote: I cannot save igi:
Error: Unsupported extension:
Saving IGI images to various formats is fixed for next release (4.0.39).
fourzeronine
Post by fourzeronine » Wed Jun 22, 2016 8:42 pm
Maybe this open source code could be of use for the developers of Indigo.
http://gpuopen.com/gaming-product/fire-rays/
Post by pixie » Wed Jun 22, 2016 10:38 pm
Having created some anims one stumble with the hurdle of having to load the full scene, building it, when most of the time only the camera moves, which in itself doesn't require nor the complete scene load nor build. It would be great if all the camera positions could be loaded upfront so it minimizes the build time.
Juju
Post by Juju » Thu Jun 23, 2016 12:58 am
Hi guys, maybe it's me, but how do you add materials to the Local Material Database (LMD)? I've gone to tools>show material folder and tried copying *.igm and *.pigm files there but they don't show up in the LMD in Indigo, even after closing the app and re-opening it. I've also tried file>import material but no luck.
Post by OnoSendai » Thu Jun 23, 2016 2:44 am
Adding support for normal mapping on GPU:
Originalplan®
Post by Originalplan® » Thu Jun 23, 2016 2:51 am
OnoSendai wrote:Adding support for normal mapping on GPU:
Thank you!
fourzeronine
Post by fourzeronine » Thu Jun 23, 2016 1:25 pm
