Indigo Renderer 4 public beta
Post by OnoSendai » Thu Apr 28, 2016 4:22 am
Fast SSS doesn't work on GPU yet.
Originalplan®
Post by Originalplan® » Thu Apr 28, 2016 4:24 am
OnoSendai wrote:Fast SSS doesn't work on GPU yet.
It worked well in the last version!! :D
4.31.
Ps: in 4.31 Tabulated data worked perfectly. In 4.36 first edit in Tabulated data or Scale the problem comes up.
Originalplan®
Post by Originalplan® » Thu Apr 28, 2016 4:35 am
Oscar J wrote:Works for me. Strange!
Very.Oscar can you please put a Tabulated data in the color channel and let's see if it still works on GPU.
Post by OnoSendai » Thu Apr 28, 2016 5:00 am
Tabulated albedo was inadvertently broken, have fixed for next release.
Originalplan®
Post by Originalplan® » Thu Apr 28, 2016 5:33 am
OnoSendai wrote:Tabulated albedo was inadvertently broken, have fixed for next release.
Thank you Ono! ^ _ ^
FakeShamus
Post by FakeShamus » Thu Apr 28, 2016 1:09 pm
just wanted to to write to confirm that resuming a render from igi works correctly in 3.8 but not in 4 (I hadn't taken the time to reinstall the older version to check)
fourzeronine
Post by fourzeronine » Thu Apr 28, 2016 2:22 pm
Thank You!
fourzeronine
Post by fourzeronine » Thu Apr 28, 2016 6:15 pm
is motion blur not implemented yet for OpenCL rendering?
Post by Oscar J » Thu Apr 28, 2016 6:25 pm
Not at the moment, but will be back in there soon enough I think.
fourzeronine
Post by fourzeronine » Thu Apr 28, 2016 7:16 pm
Oscar J wrote:Not at the moment, but will be back in there soon enough I think.
Too bad! I really need it. Just grabbed a v4 upgrade license. :D
Post by Zom-B » Thu Apr 28, 2016 7:27 pm
fourzeronine wrote:is motion blur not implemented yet for OpenCL rendering?
No but it has been speed up by +100% on CPU during the latest v4 builds!
Post by CTZn » Fri Apr 29, 2016 3:33 am
OnoSendai wrote:Have updated all download links in the first post to v4.0.36.
Thanks, veeery nice changelog ! There's just this point, generally speaking though:
* Not writing some XML elements if they have the default values - in <mesh>, <model2> etc..
Please keep in mind that Indigo's output is the main, if not the only autonomous source for looking up new features and other XML changes. I think it's fine as long as the change will allow developers to reproduce a functional code. That said, default values in meshes & models are trivial data indeed.
contegufo
Post by contegufo » Fri Apr 29, 2016 7:18 am
Hi
Fast SSS; what is the parameter that determines the depth of transparency?
Thank you
Post by OnoSendai » Fri Apr 29, 2016 7:21 am
contegufo wrote:Hi
Thank you
Scattering coefficient in medium settings as per normal.
fourzeronine
Post by fourzeronine » Fri Apr 29, 2016 7:41 am
That is great but the speed increase I am getting with the OpenCL rendering overall is fantastic. I have an animated short that I've set up in Maya and the pipeline is working great for Indigo (the viewport 2.0 and final renders both look fantastic). I have just been waiting on OpenCL integration so that I can render the whole project with a couple of Radeon Pro Duos rather than buying or renting an entire render farm. Its sort of a proof of concept and pipeline for GPU rendering.
