Indigo Renderer 4 public beta
burnin
Post by burnin » Thu Apr 21, 2016 4:51 am
Alejandro_66 wrote:How come the Beta is limited to 0.7 megapixels?
Can still render 'limitless', there are only watermarks over.
contegufo
Post by contegufo » Thu Apr 21, 2016 6:45 am
Originalplan® wrote:Hey guys,
Here is a Fast SSS test scene with the new Filmic cam setting.
@Contegufo i think you will like it :)
Link : https://infinit.io/_/fH5Mxr6
Also here is a pack of measured BRDF data for testing measured data inside Indigo Material settings.
Link : https://infinit.io/_/yDyT2GP
@Originalplan®
Congratulations for the excellent result; I have some questions for you.
1) How do you replace the sphere preview another object?
2) How does the graphic tabulated?
3) The misurate materials are read-only?
Thank you!
Post by CTZn » Thu Apr 21, 2016 8:50 am
bump re: my i7 860 not showing up as an OpenCL device while SSE4.2 compliant.
Processor Name: Intel(R) Core(TM) i7 CPU         860  @ 2.80GHz
Processor Information: Intel64 Family 6 Model 30 Stepping 5
MMXSSE Test
Module Version: 1.0.10.64b.W
Start Time: Wed Apr 20 22:32:29 2016
Test Result - PASS
 --- Determining MMX - SSE capabilities ---
		 --- CPU FEATURES DETECTION FOR ---
	            ---        MMX SSE       ---
MMX		 - MMX Supported -->	Yes
SSE		 - SSE Supported -->	Yes
SSE2		 - SSE2 Supported -->	Yes
SSE3		 - SSE3 Supported -->	Yes
SSSE3		 - SSSE3 Supported -->	Yes
SSE4.1		 - SSE4.1 Supported -->	Yes
SSE4.2		 - SSE4.2 Supported -->	Yes
		--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
End Time: Wed Apr 20 22:32:29 2016
Total Time:  seconds: 0
No very much a big deal since the graphic board is recognized as an OpenCl device alone but can't take the job ! Just willing to know more on the issue plz.
edit: unsupported features are AVX/AES/PCLMULQDQ & 'QPI link rate Test'. This whole issue might be a system update issue.
video drivers are the latest as of 4.0.31
Originalplan®
Post by Originalplan® » Thu Apr 21, 2016 8:48 pm
@Originalplan®
Thank you!
1) By right click and choosing another object as a preview item...it's really handy with double sided thin and sss.
2) You mean the color in sss? It's tabulated by scale & color.
3) Well yeah and No..they are binary files you can't really do much with them in therms of customizing them.
They are handy in real scenes where guess work does not do the trick.They representing a specified materials exact spectrum and luminance...like acrylic or marble.
To know more have a look at this :
https://disney-animation.s3.amazonaws.c ... tes_v2.pdf
thesquirell
Post by thesquirell » Thu Apr 21, 2016 8:59 pm
Has anyone tried section planes? Can't get them to work....
Originalplan®
Post by Originalplan® » Fri Apr 22, 2016 7:32 am
thesquirell wrote:Has anyone tried section planes? Can't get them to work....
They don't work here either...
Post by Oscar J » Fri Apr 22, 2016 10:59 am
The Fast SSS material is so much fun to play around with. :) About 6 minutes of rendering for this one - a sharp light source from behind + a dimmer fill/reflection light plane.
yonosoy
Post by yonosoy » Fri Apr 22, 2016 12:21 pm
very nice Oscar.
Originalplan®
Post by Originalplan® » Fri Apr 22, 2016 8:26 pm
Oscar J wrote:The Fast SSS material is so much fun to play around with. :) About 6 minutes of rendering for this one - a sharp light source from behind + a dimmer fill/reflection light plane.
Keep em coming Oscar! :)
arc en ciel
Post by arc en ciel » Sat Apr 23, 2016 12:32 am
very beautiful Oscar !
using invisible to camera setting's object
I got a difference (bug) using GPU and CPU rendering's mode with Indigo 4.0.31
square's lights objects are visible in gpu mode
CPU
http://reelmotion.free.fr/images/invisibleCpu4.jpg
GPU
http://reelmotion.free.fr/images/invisibleGpu4.jpg
P.S. : [img] is off
contegufo
Post by contegufo » Mon Apr 25, 2016 2:05 am
Hi
Festival of FSSS!
SS is set to 3 but in the Log is 2. Bug?
Originalplan®
Post by Originalplan® » Mon Apr 25, 2016 8:24 am
@contegufo Nice find!
So testin the V4 for about two weeks in. I didn't find any new & critical Bugs on my part.
Some minor stuff only but i mentioned that before (see older posts here)
There are some exporter related bugs present mainly Open CL building with instances on GPU render...but i'm pretty sure with a newer build of Cindigo it will be fixed. ( When can we try that? )
All in all V4 is pure fun! Superb upgrade to V3 it was worth the wait!
:) Keep it up guys Indigo4 is fantastic!
pzdm
R9390 performance
Post by pzdm » Mon Apr 25, 2016 9:13 am
Hello everybody
I´m just testing 9390 and R9380 and the currently using 390 is pretty slow in the car scene (something somewhere around 2,251 M/s)
I checked the GPU-Z - GPU load and it´s also pretty low, it varies somewhere between 25-70%. The RAM and everything else looks correct to me.
I use last ADM/Radeon build 16.4.1
many thanks, Pavel
Post by Zom-B » Mon Apr 25, 2016 5:42 pm
hey Pavel, thanks for testing!
have you let the Benchmark run for some minute?
At the Moment the Renderer doesn't start with full load, but needs some time to reach full GPU usage (~20sec).
pzdm
Post by pzdm » Mon Apr 25, 2016 7:25 pm
Zom-B wrote:hey Pavel, thanks for testing!
many thanks for the reply!
A picture is better than thousands words....
You can check it yourself here
P
