Indigo Renderer 4 public beta
davide445
Post by davide445 » Mon Apr 18, 2016 9:37 am
A Laubwerk generated scene with a couple of characters and 5Mil poly is working, also with 50Mil poly is working (with a 15min scene building time) with Reinhard tone mapping, using the camera did remain black.
FakeShamus
Post by FakeShamus » Tue Apr 19, 2016 9:48 am
another glitch - resuming a render from igi does not pick up where it left off, rather starts over from scratch.
this seems to be the case in both GUI and console modes.
Post by Oscar J » Tue Apr 19, 2016 10:02 am
davide445 wrote:A Laubwerk generated scene with a couple of characters and 5Mil poly is working, also with 50Mil poly is working (with a 15min scene building time) with Reinhard tone mapping, using the camera did remain black.
Curious. Have you tried the other tonemappers and cranking their values way up?
yonosoy
Post by yonosoy » Tue Apr 19, 2016 10:21 am
I´m expecting a miracle speed with clouds via GPU. This benchmark scene is an evidence.
As crazy as always. 50001 icosaedro spheres with the same Fast SSS material (preset).
about 20 min of render
Benchmark for the scene:
Dual Xeon E-5 2620v3: 0.070 sps
GTX 980: 1.290 sps
Path tracing both. Wow, no words.
PD: very far from an optimised scene for test because there are spheres inside spheres,
again a complex thing.
fast_exportation.pigs
(1.97 MiB) Downloaded 319 times
Post by CTZn » Tue Apr 19, 2016 10:29 pm
thanks for insisting yonosoy, I should really just use the fast sss for clouds testing. I have experienced better performance since Ono told that Max extinction coefficient = max absorbtion + max scattering (ps: fixed both terrain and clouds shader ie 4.0).
Originalplan®
Post by Originalplan® » Wed Apr 20, 2016 4:57 am
[BUG 4.31 OSX]
Bump Maps not working at all.
Tried in every mode CPU & GPU rendering.
(UPDATE) They work, just Scale (b) is set to a super tiny size as default so it does not recognize the texture. I set it to 1m textures magically appear & work. Maybe raise them from start up?
Scale (b) raised to 1m & bump maps work.
Post by Oscar J » Wed Apr 20, 2016 8:13 am
I think 0.001 m is a kinda good default size for bump maps - wood, stone etc. look pretty much right with that. For scales of 1 m you should definitely consider using a displacement map. :)
arc en ciel
Post by arc en ciel » Thu Apr 21, 2016 2:13 am
using 2 suns in the scene
this scene run correctly with 3.8.5
I got an error using 4.0.31
Error while building scene: only Sum material with 2 child materials supported currently.
contegufo
Post by contegufo » Thu Apr 21, 2016 2:53 am
HI
Fsss!
Originalplan®
Post by Originalplan® » Thu Apr 21, 2016 3:03 am
Oscar J wrote:I think 0.001 m is a kinda good default size for bump maps - wood, stone etc. look pretty much right with that. For scales of 1 m you should definitely consider using a displacement map. :)
Yep.But sometimes it seems not working at all untill i bimp it up to 1m and then back to 0.001.
Post by lycium » Thu Apr 21, 2016 3:04 am
Might be a bug in kernel rebuilds; when you see weird behaviour like this, you can confirm it by switching to normal CPU mode (non-OpenCL) and seeing if it works properly then. If that fixes it then please let us know :)
Originalplan®
Post by Originalplan® » Thu Apr 21, 2016 3:10 am
Hey guys,
Here is a Fast SSS test scene with the new Filmic cam setting.
@Contegufo i think you will like it :)
Link : https://infinit.io/_/fH5Mxr6
Also here is a pack of measured BRDF data for testing measured data inside Indigo Material settings.
Link : https://infinit.io/_/yDyT2GP
Originalplan®
Post by Originalplan® » Thu Apr 21, 2016 3:11 am
lycium wrote:Might be a bug in kernel rebuilds; when you see weird behaviour like this, you can confirm it by switching to normal CPU mode (non-OpenCL) and seeing if it works properly then. If that fixes it then please let us know :)
I will. Didn't had much time yesterday to test it.
Just wanted to create a material...and it seemed to not work at all untill i bumped it up to 1m.
I didn't switch CPU-GPU mode....but i will try it nextime i get this and will let you know.
Alejandro_66
Post by Alejandro_66 » Thu Apr 21, 2016 3:42 am
How come the Beta is limited to 0.7 megapixels?
Post by lycium » Thu Apr 21, 2016 3:45 am
Alejandro_66 wrote:How come the Beta is limited to 0.7 megapixels?
Non-licensed Indigo in general is. If you have a valid Indigo 4 licence there is no res limit or forced watermark.
