Indigo Renderer 3.4.2
Re: Indigo Renderer 3.4.2
Post by OnoSendai » Thu Jun 28, 2012 12:36 am
Hi Matt,
Yes, that should work fine.
Post by lycium » Thu Jun 28, 2012 12:37 am
Please update your GPU drivers before trying, absolutely crucial!
Post by CTZn » Thu Jun 28, 2012 12:41 am
lycium wrote:Please update your GPU drivers before trying, absolutely crucial!
Quoted for truth ! I remember that Indigo was the only GPU-able application that was not functioning until I updated the board drivers. Games, 3d apps were running smoothly but Indigo really required the update, plain and simple.
Get not fooled and do as lycium says !
MattMR2
Post by MattMR2 » Thu Jun 28, 2012 12:48 am
Hi OnoSendai,
Thanks for your answer !!! You're the first render engine that support it correctly... Cycle still has problem (less fast) and Octane ( Kepler version ) are not fast than the standard version. Hope nvidia will release driver and DEV kit to solve this ;)
Thanks again for your answer.
Matt
PS : Already have the lastest driver... just waiting my new card... snifff...
FakeShamus
Post by FakeShamus » Tue Jul 03, 2012 6:30 am
Am I right in assuming that the only correct settings for a normal map would be exponent (gamma) =1 and a b-value of 1? going higher than 1 seems to create a weird, artificially dark look to the whole object. is there any way to "deepen" the effect of the map in a natural way without the shading getting funky?
galinette
Post by galinette » Tue Jul 03, 2012 9:23 am
FakeShamus wrote:Am I right in assuming that the only correct settings for a normal map would be exponent (gamma) =1 and a b-value of 1? going higher than 1 seems to create a weird, artificially dark look to the whole object. is there any way to "deepen" the effect of the map in a natural way without the shading getting funky?
Add some displacement! Bump/normalmap is a quite ugly and hack, that looks right only if not pushed too much... Unfortunately.
Post by CTZn » Tue Jul 03, 2012 12:14 pm
Otherwise that's correct, the settings for normal maps are gain=1.0 and gamma=1.0, I went the same way.
galinette
Post by galinette » Tue Jul 03, 2012 8:32 pm
Sure, using any gamma other than 1.0 is ugly, as it will make the "undisplaced" value (ie RGB=128/128/255) displaced.
Etienne
FakeShamus
Post by FakeShamus » Wed Jul 04, 2012 3:58 am
CTZn wrote:Otherwise that's correct, the settings for normal maps are gain=1.0 and gamma=1.0, I went the same way.
that's what I thought, thanks!
Post by pixie » Thu Jul 05, 2012 12:30 am
BiDir MLT goes on par with BiDir PT so it seems, there are parts of the picture that one is better and vice versa.
PT
MLT
Post by CTZn » Thu Jul 05, 2012 12:50 am
Wich points me to the IGI merging feature available through the command line:
indigo_console --merge_igi [igi_list] out.igi
Merges the IGI files listed in igi_list (one per line) into out.igi. How nice is that !?
Post by pixie » Thu Jul 05, 2012 8:24 am
CTZn wrote:Wich points me to the IGI merging feature available through the command line:
Niiiice! xD
Post by PureSpider » Fri Jul 06, 2012 1:18 am
Does that command do spp-weighted merging?
Post by lycium » Fri Jul 06, 2012 1:35 am
Yes, it does it correctly :)
Voytech
Post by Voytech » Fri Jul 06, 2012 5:12 am
lycium wrote:Yes, it does it correctly :)
Could you make that function work within the GUI instead of console only?
