Indigo Renderer 3.2.0
Ryouta Sumeragi
Re: Indigo Renderer 3.2.0
Post by Ryouta Sumeragi » Thu Nov 03, 2011 11:22 pm
Thank you for big update!
In Win7(x64)SP1 environment, a problem is taking place.
* It is not exported when I use Plug-in(Cindigo) attached to the installer
* Base application (Cinema4D R10.5) crashes when I use a Japanese file name for (Cindigo\presets\materials) in the Plug-In folder
There is no problem in the service packless environment
And...
obstacle map seems not to be applied(Cindigo)
C4D R10.5 (64bit)
Indigo 3.2.0, Cindigo 3.0.15
Win7Pro(64bit), MEM 8GB
Win7Pro(64bit)SP1, MEM 16GB
I used machine translation ...
Post by fused » Fri Nov 04, 2011 12:05 am
Ryouta Sumeragi wrote:Thank you for big update!
And...
C4D R10.5 (64bit)
thank you for reporting this. Obstacle maps are currently not used by Indigo.
Did the Cindigo crash not happen with the Cindigo version you downloaded from the forum?
Regards,
Yves
Ryouta Sumeragi
Post by Ryouta Sumeragi » Fri Nov 04, 2011 12:38 am
fused wrote: Did the Cindigo crash not happen with the Cindigo version you downloaded from the forum?
Yes.
There was not a problem with Cindigo of the forum.
fbrunell
Post by fbrunell » Fri Nov 04, 2011 12:54 am
Windows 7
Blender 2.60a
Indigo 3.2.0
Blendigo 3.2.0.0
I just upgrade my Master and one of my slave to 3.2.0. I tried to generate an image render from Blender. Once Indigo starts rendering I click on Network Rendering. The slave does not connect. It used to work with 3.0.14?
Jambert
Post by Jambert » Fri Nov 04, 2011 1:00 am
I suppose next linux release will be 3.2 stable?
Jeff Hammond
Post by Jeff Hammond » Fri Nov 04, 2011 3:41 am
crashing on mac (10.7.2) with skindigo 3.2 installed.
skindigo appears to be working properly (no error messages, exports then launches indigo..)
how can i go about diagnosing the issue?
thanks
[edit]
caterpillar sample scene loads/renders correctly
Post by fused » Fri Nov 04, 2011 3:44 am
Jeff Hammond wrote:crashing on mac (10.7.2) with skindigo 3.2 installed.
thanks
Can you please email the error report to support (at) indigorenderer (dot) com?
Jeff Hammond
Post by Jeff Hammond » Fri Nov 04, 2011 3:50 am
thanks
ok, sent.
thanks
Post by OnoSendai » Fri Nov 04, 2011 5:36 am
snorky wrote:
OnoSendai wrote:* Added local material database action to toolbar.
where? single folder, entire hd? can be set?
OnoSendai wrote:* Added online database browser (Window -> Online Material Database)
please add a progression bar or a message... or add material 1 by 1 on list... because seems frozen until the end of the search!!!
..."show material folder" don't work for me...
great release!!!!
Hi Snorky,
Local material database is located in AppData folder, e.g. C:\Users\nick\AppData\Roaming\Indigo Renderer\materials
I've added notes to fix your other other points. Thanks!
Voytech
Post by Voytech » Fri Nov 04, 2011 8:19 am
Ok. I can't render ANYTHING other than the Caterpillar example scene. The other two open up and crash when finished with "Loading Energy Compensation Curve"). Nothing of my own works either. I've sent the crash report and detailed description to your support email. This is on OS X 10.7.1.
Also, you mentioned that CUDA does not work - it seems that it does. On the caterpillar scene I notice an additional 300k-400k samples/s.
Post by CTZn » Fri Nov 04, 2011 8:43 am
Could someone please tell me how GPU drivers can be updated on OSX ?
If you know try it out because it is expected to get inconsistent GPU behaviours with outdated drivers. That would even happen on Windows.
PS: Voytech, I do not have access to your report and am not Mac saavy.
Post by fused » Fri Nov 04, 2011 8:50 am
Voytech wrote:Ok. I can't render ANYTHING other than the Caterpillar example scene. The other two open up and crash when finished with "Loading Energy Compensation Curve"). Nothing of my own works either. I've sent the crash report and detailed description to your support email. This is on OS X 10.7.1.
yes, the mac build does not work very well on 10.7.x. We have located the issue and are looking into it.
CUDA does work if you have 10.6 or higher.
ENSLAVER
Post by ENSLAVER » Fri Nov 04, 2011 10:47 am
Win 7 x64
A couple of minor bugs, when changing camera settings (f-stop to autofocus, maybe more) sometimes (intermittently) it returns to a previous position/rotation.
When moving the camera quickly sometimes "ghosting" (it kind of looks like lens flares) appears - Seems to be only with pt mlt and bi mlt, apperture diffraction has no effect. I haven't tested it over a long period to see if it dissapears or has any effect on the overall scene.
Apart from that it seems to be working awesomely for me :D
alffrad
Post by alffrad » Fri Nov 04, 2011 10:56 am
Same as Jeff:
Indigo 3.2
skindigo 3.2
Mac OS 10.7.2
Indigo can render only the caterpillar scene,
If I try to export from shindig, Indigo launches and crashes every time.
Thanks!!
Post by StompinTom » Sat Nov 05, 2011 2:44 am
Alpha materials seem to be busted... My leaf materials don't seem to take into account any blend maps or such...
Users browsing this forum: No registered users and 196 guests
