Indigo Renderer 2.0.6
Post by OnoSendai » Thu May 14, 2009 5:25 pm
Hi all,
This release contains some bugfixes, but also the network rendering process has had some work done on it to make it a bit easier to use.
Check out this tutorial to see how to start a network rendering with 2.0.6. Feedback welcome!
And feel free to improve the tutorial.
http://www.indigorenderer.com/wiki/network-rendering
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_2.0.6_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_2.0.6_Setup.exe
[edit] Indigo for os x:
http://www.indigorenderer.com/dist/beta ... seimage.gz.
Changelog:
2.0.6
* Added -hardwareid command line option, prints out hardware ID string.
* removed "WARNING: Overriding material definition for .." message
* Added render thread priority combobox to gui (only for windows)
* Added Network rendering option and pane to GUI; shows all connected slaves.
* Added Network slave GUI (enabled when -n s is used.)
* Fixed recent files list
* Fixed crash with emitting glossy transparent material.
* Following include links in preliminary scene parse
* Windows installers now create shortcuts to Network Slave GUI.
* moved tree_cache and network_cache into cache
rgigante
Re: Indigo Renderer 2.0.6
Post by rgigante » Thu May 14, 2009 7:32 pm
Good improvement in terms of network rendering UI feedback. Very well done!
R.
Post by suvakas » Thu May 14, 2009 7:58 pm
Very nice update.
I really love the improved network rendering.
Also the new slave window is very cool.
+ Thanks for so quick bug fixes.
Post by zeitmeister » Thu May 14, 2009 8:21 pm
I've got a question:
Is it too complicated to compile the Mac version along the Windows or Linux versions, or what is the reason why there aren't neither builds of the 2.05 nor the 2.06 beta?
Do I have to imply to that when I buy Indigo for Mac?
Don't get me wrong, I'm not trying to bully in any way, I am just wondering.
Post by Pibuz » Fri May 15, 2009 2:20 am
Hi guys! Hi Ono! Thanks for the update!
Listen, I've got a tiny annoying thing going on: the icons of "Indigo.exe" and "Indigo Renderer Network Slave.exe" are the generic icons windows uses for generic executable apps (white rectagle with a blue string in the top), and not the fancy-coloured one which I can see in the header here, for example. How can I fix that?
I'm running Indigo on Win XP 32bits.
Thank you guys.
Post by pixie » Fri May 15, 2009 7:46 am
IMO the thread's priority should be 'below normal' as default... it's always easier to turn it normal then it is to turn it below normal
Doug Armand
Post by Doug Armand » Fri May 15, 2009 2:13 pm
Get this error message when I try and render by exporting from Blendigo. The .igs gets created ok and
I can load it direct from the Indigo GUI and it then renders fine
Blender 2.49a, Win 7 RC x64, Blendigo 1.1.18
Post by PureSpider » Fri May 15, 2009 8:15 pm
I bet its the space in the filename :D
Doug Armand
Post by Doug Armand » Fri May 15, 2009 8:24 pm
[quote="PureSpider"]I bet its the space in the filename :D[/quote]
What space? either way it worked for versions prior to this
Post by PureSpider » Fri May 15, 2009 8:34 pm
"Dougs Stuff" that one
Post by zeitmeister » Fri May 15, 2009 8:36 pm
Very very nice, thanks a lot!
Doug Armand
Post by Doug Armand » Fri May 15, 2009 8:39 pm
[quote="PureSpider"]"Dougs Stuff" that one[/quote]
hehe you may be right - but I've always used that folder name. I've since tried a new file in that same folder structure and that seems to render fine. Not sure whats causing it.
Doug Armand
Post by Doug Armand » Fri May 15, 2009 9:47 pm
same error again but different file. As before exporting from Blendigo gives this error message. I can then load the .IGS file and it works. The only space in this is the folder 'Dougs stuff'. But I have had that same folder structure for ages so I think this is something else.
Post by zeitmeister » Fri May 15, 2009 10:03 pm
Can't initialize Indigo beta 2.0.6 for Mac. :-(
Bild 1.png (16.11 KiB) Viewed 31146 times
Post by OnoSendai » Sat May 16, 2009 7:19 pm
Pibuz wrote:Hi guys! Hi Ono! Thanks for the update!
Thank you guys.
Hi Pibuz,
The icons aren't working on XP, but only Vista for some reason. I'll fix that soon.
Users browsing this forum: No registered users and 154 guests
