Indigo 1.1.16
Grimm
Post by Grimm » Sun Feb 08, 2009 11:23 am
I can confirm SATtva's error, JPEG files that worked before no longer will load. I'm also on the 64-bit version of Linux. I did try and load and save the files with Gimp but it didn't help. My usual image viewers and Gimp will load the files just fine. This is running Indigo v1.1.16.
Grimm
Post by OnoSendai » Mon Feb 09, 2009 5:07 pm
Big Fan wrote:been trying out network rendering and I found that it will not halt on samples
I have no idea when this might have become an issue or if it is usually like this -
used my old P2.66 as a master(UImode) and new duo @3.8ghz as slave(console mode)
at predetermined samples the master recognises the halt and says its quitting but doesnt- it just keeps saying that :?
I would have thought it would quit the slave as well but..
here is a screenie of the ongoing quit cycle
Thanks for bug report, fixed.
Post by OnoSendai » Wed Feb 11, 2009 11:55 am
SATtva_ wrote:Here's another problem. Starting 1.1.16 on the scene (exported with Blendigo 1.1.14) I get this obscure error message:
Warning: failed to decode texture '../textures/metal/scratches_bump.jpg'.
Error: IndigoDriverExcep: SceneLoaderExcep: Failed to load texture '../textures/metal/scratches_bump.jpg' (In element 'texture', around line 75, column 13): ImFormatExcep: Error while reading JPEG file: Bogus message code %d
However 1.1.15 on the same scene with the same texture file works flawlessly (well, except for black triangles). I've attached texture file below.
Thanks for bug report, fixed for next release.
SATtva_
Post by SATtva_ » Wed Feb 11, 2009 9:31 pm
Nice to hear that, Ono, thanks.
lolko7
Post by lolko7 » Wed Feb 18, 2009 2:13 am
Welcome
Ono, Could You make next release for libtiff3 (libtiff.so.3)? My OS is openSUSE 11.1 64bit. I have only libtiff.so.3 and I can't upgrade to libtiff.so.4
Greetings
joegiampaoli
Post by joegiampaoli » Wed Feb 18, 2009 10:04 am
have you tried:
1) Maybe a symlink will still work it out?
or
2) Downloading, compiling it a installing it in another place like /opt and create symlinks to /usr/local with stout?
Joe Giampaoli
My Indigo Gallery
MSUdom5
Post by MSUdom5 » Wed Feb 18, 2009 11:03 am
lolko7 wrote:Welcome
Greetings
Unfortunately, this is one of the disadvantages of having so many different flavors of linux using different repositories. Different distributions update repositories with newer versions of libraries at different times.
Keeping Indigo up-to-date with the latest versions of libraries is important, so I wouldn't expect subsequent releases to work with old libraries. In your case, the best thing to do is download the newest version of libtiff, compile from source, and add the new libraries to your library path.
joegiampaoli
Post by joegiampaoli » Wed Feb 18, 2009 11:08 am
sorry I'm thinking of beer :P
Not stout it's stow
Joe Giampaoli
My Indigo Gallery
coryalantaylor
Post by coryalantaylor » Tue Mar 03, 2009 9:56 am
Where can I get the Blendigo exporter for 1.1.16?
Post by Borgleader » Tue Mar 03, 2009 10:05 am
There is none. Version 1.1.14 will work just fine.
Post by Kram1032 » Tue Mar 03, 2009 10:07 am
same as 1.1.15 ;)
Pilgrim
Re: Indigo 1.1.16
Post by Pilgrim » Mon Apr 27, 2009 8:04 am
For some reason I can't download the Windows 32bit version. All other DL ok, but Win32 only generates a 1kb file.
Anyone got an alternative URL that I can download from?
Users browsing this forum: No registered users and 93 guests
