Indigo 1.1.15
dougal2
Post by dougal2 » Sat Jan 03, 2009 9:15 am
mateuszdraco
funny that the speed difference is almost exactly a factor of two ... did you perhaps use 1 thread on linux and 2 on windows ?
Post by OnoSendai » Sat Jan 03, 2009 1:55 pm
Big Fan wrote:so is the background and env-map code deprecated now?
<tex_coord_generation>
<spherical> ....and also <lat_long>?
<rotation>
<axis_rotation>
<axis>0 0 1</axis>
<angle>1.6</angle>...radians?
the tex index means multiple .exr for 'env maps' if desired?
Hmm, the background and env-map XML code will stick around for now.
Yes, you can do all kinds of crazy sh*t like multiple env map textures, or even use shaders for the background if you want :)
Re: win vs lin (both x64)
Post by OnoSendai » Sat Jan 03, 2009 1:57 pm
mateuszdraco wrote:hi, everyone, it's my first post here ;)
I did some little experiment about render speed at my computer, and tbh im really suprised
As dougal2 said, please check you are using the same number of threads in both tests. The speeds of the linux build and windows build should be pretty similar.
mateuszdraco
Post by mateuszdraco » Sat Jan 03, 2009 9:39 pm
dougal2 wrote:funny that the speed difference is almost exactly a factor of two ... did you perhaps use 1 thread on linux and 2 on windows ?
well, you may have right but...
OnoSendai wrote:As dougal2 said, please check you are using the same number of threads in both tests. The speeds of the linux build and windows build should be pretty similar.
how to check & change it?
Post by OnoSendai » Sat Jan 03, 2009 10:00 pm
Have a look in log.txt, just before it starts rendering.
Anthor
Post by Anthor » Sun Jan 04, 2009 5:22 am
I have this warning: " WARNING: Failed to open log file at 'log.txt' for writing."
and
why is present folder .svn in windows version ?
(translated by google) :oops:
thank's
Post by CTZn » Sun Jan 04, 2009 6:11 am
Make sure that the Indigo folder is not write protected; the svn folders can be safely discarded.
Look in the manual in the renderer settings section, the option called num_threads. The number of threads used is specified in the output/log when the scene has finished loading, and before the render starts.
Big Fan
Post by Big Fan » Sun Jan 04, 2009 6:41 pm
ok ono done that or at least 1st approximation - now what about the lat-long case...
what is the xml for that please - or is that still coming?
called it Skymap until I remove the old stuff ;)
edit:2nd approx :)
edit:3rd approx :D
ok no.4 ;)
attach also here is a simple scruffy trial render with a shader used as a background - this is ono's grid shader from the 'shader' thread
not sure why it started out with a bright square in it though :?:
possibly will hard code this in with some settings for grid size..
Anthor
Post by Anthor » Mon Jan 05, 2009 12:08 am
CTZn wrote:Make sure that the Indigo folder is not write protected;
Thank's for your time :) , i tried with administrator user and i tried on another computer and have same problem.
Ciao :D
Post by CTZn » Mon Jan 05, 2009 12:30 am
Looks like for me that you are stuck, Anthor, by luck I'm no expert in that field :) And I'm of no help at all if you use linux, but you'd have said 'root' not admin !? Maybe setting application paths in linux is trickier
I presume you can find this line into the <renderer_settings> section of the igs file:
<logging>true</logging>
or Indigo would not look for it... :?
Despite admin rights, I believe you should check the write access of the folder Indigo resides in (right-click on the folder > properties. admin access doesn't remove write protection byte), some portable drives might mark their content protected by default when coping it out ...
Well that's just a hint, never heard about this error before.
Anthor
Post by Anthor » Thu Jan 08, 2009 3:29 am
for news, I tried on another PC, I downloaded the program, unpacked, indigo launched and run a test file ... same problem
is not a real problem is just an alert
Ciao :)
Post by Zom-B » Thu Jan 08, 2009 3:51 am
I can confirm this issue on 2 systems!
SATtva_
Post by SATtva_ » Thu Jan 08, 2009 4:16 am
Here on Linux AMD64 logging works fine.
mateuszdraco
Post by mateuszdraco » Thu Jan 08, 2009 8:19 am
Well i can confirm problem with logging - i deleted log.txt, it reappeared but message was still the same - cant open for writing. And log.txt is always empty.
(checked only on vista ;))
SmartDen
Post by SmartDen » Thu Jan 08, 2009 8:30 am
i thought i'm alone with the problem :) can also confirm it
Check normals, dude!
