Indigo 1.0.1
Post by OnoSendai » Sun Oct 21, 2007 3:10 am
Yes, the number of values must equal the number of values :)
Post by Kram1032 » Sun Oct 21, 2007 3:11 am
lol, that sentence reads very strange, now ;)
N_o_S = NoS :)
Pinko5
Post by Pinko5 » Sun Oct 21, 2007 3:39 am
:shock: :shock: :shock: Ono!!!!!!
Pinko.;)
zsouthboy
Post by zsouthboy » Sun Oct 21, 2007 5:14 am
Was not expecting your 1.0 branch to show up so soon :D
Thanks Ono!
Kosmokrator
Post by Kosmokrator » Sun Oct 21, 2007 5:18 am
i believe....more unbelievable things to come in future releases... :wink:
New perseption of 3d computer image generated graphics will come!!!
:twisted: :twisted:
Camox
Post by Camox » Sun Oct 21, 2007 5:53 am
Thanks Nick ! :D :D :D :D :D
Post by Zom-B » Sun Oct 21, 2007 6:21 am
OnoSendai wrote:What's the problem with ur pool scene?
There is an FireFly party going on at the pool! The longer it take, the more friends get invited :evil:
the Fireflies don't like to swim, so no of them is visible in the water.
I removed exponent_map & bump map, but the result still isn't satisfying (see attachment):?
the scene is lightened by an env_map... model is a pool box (with thickness), and an water plane inside (depth ~1.7m).
BTW: Ono, could you give us some data examples for the regular_tabulated spectrum type, or maybe somebody else could drop some lines about this...
Its like getting a alien spaceship for birthday... its totally cool, but I have no Idea how to handle it and what it actually does :oops:
~ 100 samples per pixel (45min) pool is textured phong with exponent of 1000
filippo
Post by filippo » Sun Oct 21, 2007 6:58 am
wonderfull!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :D
filippo
tizxx
Post by tizxx » Sun Oct 21, 2007 7:33 am
:D
As always ...
SUPERB !
Thank you very much. Nicholas.
Post by Kram1032 » Sun Oct 21, 2007 9:02 am
if you want under water caustics, you should make your water a volume.
I've no idea, if that'd affect the above fireflies in *any* way....
@ Ono: why do you need the value-amount in the tabulated spectrum? can't you "simply" check, how many values there are?
Oh, and what's if you want to have a-linear values? For example, if there is a peak at, say, 454.5 nm but you don't want to give enough details for half-nano-meters? :)
what about:
[wave length] : [value] ? :)
definitely minor. In most cases, linear exactness will be enough :)
WytRaven
Post by WytRaven » Sun Oct 21, 2007 9:06 am
@ Kram:
If you have nonlinear values then interpolate them to get linear values.
See this for an example of how it should be done :)
http://www.indigorenderer.com/joomla/fo ... php?t=2838
Post by Kram1032 » Sun Oct 21, 2007 9:08 am
I said, it's very low prior. ;)
I know, that you can interpolate them. :)
CoolColJ
Post by CoolColJ » Sun Oct 21, 2007 9:44 am
can it be used for all material types not just diffuse as in the example?
Absorption and scattering as well?
IOR?
CoolColJ
Post by CoolColJ » Sun Oct 21, 2007 10:13 am
<start_wavelength>0.4E-06</start_wavelength>
<end_wavelength>0.7E-06</end_wavelength>
how do you read these wavelengths?
What would 350nm to 750nm be in these values?
Big Fan
Post by Big Fan » Sun Oct 21, 2007 10:25 am
well I'm going to be the fly in everyones ointment ( if I'm not already) and suggest that this may be increasing accuracy but its adding needless complexity.
when it comes down to it people wanting to use a renderer for commercial purposes aren't going to want to read through screeds of scientific data and camera measurements - they want to get a render out.
what is the point of modelling a particular Nikon or Canon camera for instance?
I think this calculated accuracy stuff can be taken too far.
I am not saying ono isn't doing a very good job its just I think there needs to be a reality check on it usefulness
If people can access a few accurate presets thats helpful - if they need to study the whole subject and an in depth manual it sucks up time they don't have :roll:
my 2 cents
Users browsing this forum: No registered users and 104 guests
