by OnoSendai » Thu Apr 13, 2017 5:35 am
This is a Beta release.
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.0.50_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.0.50.tar.gz
IndigoRenderer4.0.50.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.0.50_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.0.50.tar.gz
IndigoRT4.0.50.dmg
Changelog:
4.0.50
* Optimised tone mapping, especially camera and filmic tone mapping.
* Optimised CPU rendering. CPU rendering should be a few percent faster, depending on the scene.
* GPU PT: Fixed alpha being wrong when multiple light layers are used.
* GPU PT: Added 'max path depth' spinbox for OpenCL rendering.
* GPU PT: Added support for changing the env map while rendering.
* Fixed issue with network rendering updates not working.
* Fixed issue with render not being able to be restarted after an error-inducing realtime change.
Silverwing
by Silverwing » Thu Apr 13, 2017 6:19 am
Holy moly, that´s what I call great service!
Great to see the ray depth integrated. That´s a great plus!
Thank you!
by zeitmeister » Thu Apr 13, 2017 7:38 am
Very cool improvements!
pavoda
by pavoda » Thu Apr 13, 2017 8:02 am
Super!!!
by pixie » Thu Apr 13, 2017 8:27 am
OnoSendai wrote:* GPU PT: Added 'max path depth' spinbox for OpenCL rendering.
How does one summon this feature?
by Oscar J » Thu Apr 13, 2017 8:33 am
pixie wrote:OnoSendai wrote:* GPU PT: Added 'max path depth' spinbox for OpenCL rendering.
It's under the OpenCL device settings :)
TonyD
by TonyD » Fri Apr 14, 2017 3:19 am
Wow! -
The big ".50"...!
We're getting old.....
Anyway, congrats on this great release :)
by OnoSendai » Fri Apr 14, 2017 3:20 am
Yup, 50 different beta releases
phew
by pixie » Fri Apr 14, 2017 6:17 am
Oscar J wrote:pixie wrote:OnoSendai wrote:* GPU PT: Added 'max path depth' spinbox for OpenCL rendering.
Silly me! I just needed to scroll over! :)
mateuszMDA
by mateuszMDA » Sun Apr 23, 2017 9:49 pm
Hello!
I've encountered a slight problem. Mesh seems to be rendered weirdly now (see the attached picture). The problem didn't exist in v4.0.40. What might be the cause?
It appears I can overcome this by setting higher than default maximum number of subdivs in blendigo/indigo, but still... 4.0.40 worked just fine in that case.
Blendigo 3.8.25.1 (the previous version worked exactly as this one so it seems to be indigo problem).
yonosoy
by yonosoy » Mon Apr 24, 2017 2:36 am
Physicall aperture difraction not working.
by OnoSendai » Mon Apr 24, 2017 3:18 am
mateuszMDA wrote:Hello!
Are you using Indigo subdiv here?
Try setting 'Num Smoothings' in mesh settings to a higher value.
by Zom-B » Mon Apr 24, 2017 4:06 am
Hey mateuszMDA,
thanks for taking the time and reporting!
Can you maybe upload a pigs and the blend file for this scene, so people can take a look at it?
bahamut
by bahamut » Mon Apr 24, 2017 8:47 am
Hello.
I got this one while trying to render short animation.
First frame renders well, then this appears. If i render next frame manually it works well.
Both versions 48 and 50
M.
Users browsing this forum: No registered users and 109 guests
