Indigo Renderer 4.0.45 Beta Release
Post by OnoSendai » Fri Sep 09, 2016 12:51 am
This is a Beta release.
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.0.45_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.0.45.tar.gz
IndigoRenderer4.0.45.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.0.45_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.0.45.tar.gz
IndigoRT4.0.45.dmg
Changelog:
4.0.45
* GPU PT: Building OpenCL programs for multiple devices on same platform should be faster now.
* GPU PT: Worked around memory leak issue on RX 480.
* GPU PT: Improved build status and render timer text so that the build status is shown as completed only when the opencl program building is done.
* Found way to properly reload theme, removed "Please restart Indigo to fully load the theme." message box.
* Added theme support to network manager and network slave UI.
* Fixed material uploads giving an error message.
Originalplan®
Re: Indigo Renderer 4.0.45 Beta Release
Post by Originalplan® » Fri Sep 09, 2016 7:24 am
OnoSendai wrote: * GPU PT: Building OpenCL programs for multiple devices on same platform should be faster now.
It is faster. :)
Also can we add a hint of #97999B to the marked UI arrows?
They kinda get lost in the back. ( see marked screenshot )
STUDIO AARON
Post by STUDIO AARON » Fri Sep 09, 2016 9:46 am
rx 480 is up and running nicely, no more memory issues. :)
Still having issues with network slaves not connecting to the master with 4.0.42 and newer.
The issue isn't present in 4.0.41
Thanks for all the hard work!
contegufo
Post by contegufo » Fri Sep 09, 2016 10:22 am
Hi
The dark style interface does not always seem to work properly.
The new icons are more harmonized with the dark interface while the default setting were more consistent the old ones.
It would interesting if there might be an automatic update when new materials were available.
Post by Oscar J » Fri Sep 09, 2016 10:46 am
contegufo wrote:Hi
You're not running the latest Indigo version...?
contegufo
Post by contegufo » Fri Sep 09, 2016 11:09 am
You just downloaded 4.0.45.
Post by Oscar J » Fri Sep 09, 2016 6:15 pm
Your screenshot was an older Indigo version. The dark and light theme have separate icons so that nothing clashes.
contegufo
Post by contegufo » Fri Sep 09, 2016 7:29 pm
occasionally it happens .........
Indeed I must say that I went from 0.43 to 0.45. Changing icons occurred in 0.44 that I have NOT ever downloaded!
Post by Oscar J » Fri Sep 09, 2016 7:34 pm
Restarting Indigo should probably help.
contegufo
Post by contegufo » Fri Sep 09, 2016 7:41 pm
problems......
contegufo
Post by contegufo » Fri Sep 09, 2016 7:45 pm
restart et voilà!
contegufo
Post by contegufo » Fri Sep 09, 2016 7:52 pm
Post by Zom-B » Fri Sep 09, 2016 7:56 pm
contegufo wrote:????
contegufo
Post by contegufo » Fri Sep 09, 2016 8:14 pm
are bugs that are fixed ......
What the next news?
Asticles
Post by Asticles » Fri Sep 09, 2016 9:37 pm
Thanks for the 480 fix, will test tonight.
Thanks
