Indigo Renderer 4.0.42 Beta Release
Post by OnoSendai » Sat Jul 30, 2016 2:01 am
This is a Beta release.
Indigo for Windows 64-bit:
IndigoRenderer_x64_4.0.42_Setup.exe
Indigo for Linux 64-bit:
IndigoRenderer_x64_v4.0.42.tar.gz
IndigoRenderer4.0.42.dmg
Indigo RT for Windows 64-bit:
IndigoRT_x64_4.0.42_Setup.exe
Indigo RT for Linux 64-bit:
IndigoRT_x64_v4.0.42.tar.gz
IndigoRT4.0.42.dmg
Changelog:
4.0.42
* Added preliminary support for 'trackball' style camera navigation.
Ctrl/Command + left mouse button + mouse drag to rotate camera around target point
Ctrl/Command + middle mouse button + drag to pan target point and camera
Ctrl/Command + right mouse button + drag to zoom in / out from target point
Ctrl/Command + double left click to manually select target point
* Added crosshairs to OpenGL preview.
* Added crosshairs to main render view, which display only when Ctrl/Command, Alt, or camera movement buttons are held down.
* Fixed issue with phong with roughness param and no exponent param being parsed as old phong.
* Fixed fast_sss option on medium not being serialised to scene files.
* GPU PT: Fixed bad sampling of basic phong nkdata mats.
* GPU PT: Added support for new-FBM ISL func.
contegufo
Re: Indigo Renderer 4.0.42 Beta Release
Post by contegufo » Sat Jul 30, 2016 6:24 pm
HI
It would need three crosshairs to have the certainty of maintaining the parallelism.
Originalplan®
Post by Originalplan® » Sat Jul 30, 2016 10:18 pm
4.0.42
Wow everything sounds great!! Great job!
Will test this crosshairs and Ctrl/Command stuff :)
Zalevskiy
Post by Zalevskiy » Tue Aug 02, 2016 3:17 am
del
Originalplan®
Post by Originalplan® » Wed Aug 03, 2016 4:48 am
Can't seem to be able to upload materials to the database...Is that a BUG or just by me?
Post by OnoSendai » Wed Aug 03, 2016 6:33 am
Originalplan® wrote:Can't seem to be able to upload materials to the database...Is that a BUG or just by me?
What happens? Do you get an error message?
Originalplan®
Post by Originalplan® » Wed Aug 03, 2016 7:03 am
Maybe it's me....but worked fine in ver 3.xx
Than this
First this
Eneen
Post by Eneen » Wed Aug 03, 2016 7:36 pm
IHMO pan mode with ctrl should be reversed, now it's same as with alt key.
Post by Oscar J » Wed Aug 03, 2016 7:45 pm
^ I have brought this up with Nick, hopefully there will be an option to switch.
STUDIO AARON
Post by STUDIO AARON » Thu Aug 04, 2016 5:20 am
When I "Export Scene Tab Animation", skatters are not being rendered in the scenes. Works with "Render with Indigo" button and "Export Scene As" but not "Export Scene Tab Animation".
arc en ciel
Post by arc en ciel » Mon Aug 08, 2016 2:09 pm
I got a strange result with motion Blur (on a wheel)
http://reelmotion.free.fr/images/bugDisplayMB.jpg
the rear wheel disappears depending on the camera angle
here a link for a pigs, if you move around the rear wheel (zoom-in, pan right/left), it'll disappears/appears partially
https://www.wetransfer.com/downloads/b3 ... 755/850f59
Post by zeitmeister » Tue Aug 09, 2016 12:04 am
You have to crank the subsampling up to 12-20.
I know that issues very well from my last job.
http://indigorenderer.com/node/2152
Cheers, zeiti
arc en ciel
Post by arc en ciel » Tue Aug 09, 2016 3:47 am
thank's Zeitmeister.
You did an impressive job with this project ! Fantastic !
it's Heyne Drive simulator vehicule ?
how did you manage the water on the beach at the end of the clip, when all trucks are together ?
Post by zeitmeister » Tue Aug 09, 2016 6:18 am
arc en ciel wrote:thank's Zeitmeister.
Thank you!
The car was animated with Craft Animations; the water at the very end is video footage 3D-comped in After Effects... due to a strict deadline; there was any time for real 3D water, foam and realistic surf. ;-)
CoolColJ
Post by CoolColJ » Tue Aug 09, 2016 10:31 am
Bedroom benchmark - memory allocation error on my GTX 1070 :(
Also when sleecting OpenCL rendering, even with the GTX 1070 ticked, it says no device selected.
I have to untick and tick again to get it to work
