Indigo Renderer 3.6.12 Beta Release
8 posts • Page 1 of 1
Post by OnoSendai » Tue May 07, 2013 5:39 am
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.6.12_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.6.12_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.6.12.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.6.12.tar.gz
Indigo for Mac OSX (10.6 - 10.8 ):
IndigoRenderer3.6.12.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.6.12_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.6.12_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.6.12.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.6.12.tar.gz
Indigo RT for Mac OSX (10.6 - 10.8 ):
IndigoRT3.6.12.dmg
Changelog:
3.6.12
* Added igi file type association on Mac, Windows.
* Fix for crash in displacement when verts were not referenced by tris or quads.
* Made startup time for scenes with many emitters much smaller.
* Fixed view > zoom to selection command in GUI.
* Fixed: issue with dark edges after saving image with alpha as IGI, then loading it as image.
* Fixed bug where wrong GPU device was sometimes being reported as being used.
* Fixed issue where GPU preference was not cleared correctly upon scene network rendering transfer.
* Added email link to about dialog for support and feedback.
* Fixed IGI merging. (--merge_igi command)
* When resuming from an IGI in the GUI, set resolution to that in the IGI.
* When resuming from an IGI in the GUI, use scene path from the IGI if it is valid (file exists).
wlf_alex
Re: Indigo Renderer 3.6.12 Beta Release
Post by wlf_alex » Tue May 07, 2013 8:23 am
Thanks a lot, Ono !
M-Pixel
Post by M-Pixel » Tue May 14, 2013 8:07 am
THX
Post by zeitmeister » Thu May 16, 2013 4:03 am
Hi Ono,
I've got massive problems here to install Indigo on my Bootcamp-Win7-x64-partition...
attached some problem reports; I don't know if they can help you to solve my problem.
Could you please have a look?
Thank you in advance!
install_error.zip
(5.75 MiB) Downloaded 896 times
Post by fused » Thu May 16, 2013 5:40 am
zeitmeister wrote:Hi Ono,
Hi David,
it seems to be some kind of OpenCL issue.
Do you have the latest drivers for your GPU installed?
Cheers!
Yves
Post by zeitmeister » Thu May 16, 2013 5:49 am
Under Windows?
Don't know... I'll check it tomorrow, thank you!
Post by zeitmeister » Thu May 16, 2013 8:52 pm
Installed latest AMD Catalyst and it works!
Thank you very much!
Post by fused » Thu May 16, 2013 10:41 pm
zeitmeister wrote:Installed latest AMD Catalyst and it works!
Awesome. Glad you could fix it.
Your crahdump surely helped :)
