Indigo Renderer 3.6.11 Beta Release
Post by OnoSendai » Wed Apr 17, 2013 3:26 am
This is a Beta release.
Indigo for Windows 32-bit:
IndigoRenderer_3.6.11_Setup.exe
Indigo for Windows 64-bit:
IndigoRenderer_x64_3.6.11_Setup.exe
Indigo for Linux 32-bit:
IndigoRenderer_v3.6.11.tar.gz
Indigo for Linux 64-bit:
IndigoRenderer_x64_v3.6.11.tar.gz
IndigoRenderer3.6.11.dmg
Indigo RT for Windows 32-bit:
IndigoRT_3.6.11_Setup.exe
Indigo RT for Windows 64-bit:
IndigoRT_x64_3.6.11_Setup.exe
Indigo RT for Linux 32-bit:
IndigoRT_v3.6.11.tar.gz
Indigo RT for Linux 64-bit:
IndigoRT_x64_v3.6.11.tar.gz
IndigoRT3.6.11.dmg
Changelog:
3.6.11
* Thin glass etc.. now has zero alpha for transmitted light.
* Loading alpha channels of EXRs.
* Fixed garbling when saving to EXR.
* Fixed display of loaded images with alpha channels.
* Made GetAdaptersInfo loop a few times until it succeeds.
* Fixed some numerical issues with ray-sphere intersection.
Stinkie
Re: Indigo Renderer 3.6.11 Beta Release
Post by Stinkie » Wed Apr 17, 2013 3:44 am
Thanks.
Post by CTZn » Wed Apr 17, 2013 4:10 am
Thank you !
wlf_alex
Post by wlf_alex » Wed Apr 17, 2013 4:12 am
Thanks a lot, Ono !!!
Post by Pibuz » Tue Apr 30, 2013 12:48 am
Sorry guys: how is the "new" alpha background rendering feature supposed to work? I have some issue trying to use that..
Post by Zom-B » Tue Apr 30, 2013 1:11 am
Pibuz wrote:Sorry guys: how is the "new" alpha background rendering feature supposed to work? I have some issue trying to use that..
Its a checkbox in the Render Settings and instead of rendering Indigo Sky or background HDRI you get transparency at that area.
Also transparency behind glass like glass windows becomes transparent but keeps the reflections. see this car windows as an example: http://www.indigorenderer.com/node/1868
Post by Pibuz » Tue Apr 30, 2013 1:39 am
Don't want to sound jerky, but don't you think it could be too slow in complex scenes?
I mean, black/white was complete in 10 minutes max.. And it worked fine most of the times when you could sacrifice reflections..
Post by Oscar J » Tue Apr 30, 2013 3:15 am
Hi Pibuz,
IMO this is one of the greatest new features we've been spoilt with for a long time. It allows me, as an automotive renderer, to render the car with a HDRI and an asphalt ground (which I set to "invisible to camera") without actually seeing anything else than the car in the render, apart from in the reflections. And, best of all, it's done all at once - the object and its materials gets rendered at the same time as the alpha
This, together with the shadow catcher feature, allows for easy integration with a backplate.
For example, you could render an entire room with an ugly HDRI - with the alpha box checked, and then just pick an environment to place outside - using only one render (and no magic tool struggling or ugly white lines at the edges).
Post by Zom-B » Tue Apr 30, 2013 3:18 am
Pibuz, now you don't need to render an extra pass but have full Alpha support also for DOF and Motion Blur and (semi)transparent Materials. This stuff wasn't manageable with previous BW render...
The rendering doesn't take extra time but renders the alpha on the run.
Its a win-win situation :)
Post by Pibuz » Tue Apr 30, 2013 5:15 am
..oh...I see... Used to the former method, I launched the last rendering without it....
Thanks for the explaination Zom-B! As always :)
chiataimakro
Post by chiataimakro » Tue Apr 30, 2013 4:19 pm
scene with 3 glass cups. everything looks fine, but after i switch the device to i7 3610QM(OpenCL):
very cool artifact. i think it's a problem of floatingpoint precision..
delle
Post by delle » Wed May 01, 2013 5:44 pm
Cool!
Post by CTZn » Wed May 01, 2013 8:01 pm
chiataimakro wrote:scene with 3 glass cups. everything looks fine, but after i switch the device to i7 3610QM(OpenCL):
Is the scene scaled correctly ?
If this can be reproduced but not fixed I'm betting that Glare Tech would use the PIGS. Pack the scene using the Indigo packing tools and send it please to support@indigorenderer.com.
lape
Post by lape » Sun May 05, 2013 3:17 am
Is the shadow pass render mode working with Indigo RT? Just installed 3.6.11 but can't find the checkbox for this mode....
Post by fused » Mon May 06, 2013 11:26 pm
lape wrote:Is the shadow pass render mode working with Indigo RT? Just installed 3.6.11 but can't find the checkbox for this mode....
Hi lape,
it might not be supported by Indigio RT at the moment.
We are currently still evaluating which of the new features will be available in the 3.6 stable version of Indigo RT.
