Voytech
by Voytech » Fri Aug 03, 2012 11:48 pm
Headroom wrote:Oscar J wrote:FakeShamus wrote:Good Stuff! Orthographic camera is very exciting!
Couple peeves as a Mac user:
Command-Q still reloads the scene, instead of quitting the application.
And we are still missing the "File > Save Material" menu for saving materials from an open scene (apparently this shows up in the property editor pane for Windows users - but we don't get it in OSX).
thanks!
+1. Don't neglect us mac users!
+ 1 to that ;-)
+1
It's very annoying.
by suvakas » Sat Aug 11, 2012 12:58 am
If I put sun and sky to separate layers, then sky renders black on final image.
Anyone else has this issue?
solarray
by solarray » Sat Aug 11, 2012 8:07 pm
suvakas wrote:If I put sun and sky to separate layers, then sky renders black on final image.
Here it works.
by suvakas » Sat Aug 11, 2012 10:17 pm
Sky seems to work ok here too now. Don't know why it didn't work the other day.
One thing that does not work is:
<save_images_on_close>
Could you guys please fix this?
steven369
by steven369 » Mon Aug 13, 2012 1:52 am
Hi Suvakas,
the other day, my 3.2 Version did the same. I found GPU-Mode and
eventually toggling Glass-acceleration to be the problem - Don't know
nothing about the technics, but maybe it helps!
Cheers
Stephan
suvakas wrote:Sky seems to work ok here too now. Don't know why it didn't work the other day.
by fused » Mon Aug 13, 2012 10:08 pm
Hey Suv,
Everytime I test it it seems to work.
Can you provide a scene and steps to reproduce?
by suvakas » Tue Aug 14, 2012 8:17 am
Hey Yves,
Here's a scene. Turn off any light layer(s) and close Indigo.
Changes are not saved to png.
Basically all the changes you make to light layers get dismissed.
- save_on_close_bug.pigs
- (25.23 KiB) Downloaded 435 times
Xaon
by Xaon » Tue Aug 14, 2012 8:20 pm
J'ai un soucis lors de l'ouverture d'Indigo :
Je n'avais pas ce problème en version précédente...
by CTZn » Tue Aug 14, 2012 11:48 pm
Xaon wrote:J'ai un soucis lors de l'ouverture d'Indigo :
- Quelle version d'Indigo utilisait-tu précédemment ?
- As-tu installé une autre application dans l'intervalle ?
Attends, je vais demander confirmation ici mais d'autres semblent avoir trouvé une solution générique.
Vois
ce topic si tu utilise Windows Vista (et aussi dans certains cas pour seven), il semblerait qu'il faille cette mise à jour.
Plus de résultats Google:
https://www.google.fr/search?q=%22confi ... utf-8&aq=t
Le lien de la MAJ:
http://www.microsoft.com/fr-fr/download ... px?id=5638
Question to the Glare team: The issue that Xaon is bumping into might be linked to an outdated redistributable, however it didn't happen with the Indigo version he was previously using (I've asked him wich). Does it make sense to proceed to the linked update ? Did I pin the issue down already ?
Xaon
by Xaon » Wed Aug 15, 2012 7:44 pm
J'utilisais la version 4.3.0 précédemment. J'ai installé la mise à jour de ton lien et redémarré mon PC mais toujours le même problème. Je n'ai pas installé d'autres applications entre temps.
SmartDen
by SmartDen » Wed Aug 15, 2012 7:47 pm
Linux 32 GUI Build still crash on my computer. I suppose it is becouse i don't have supported video card or my card don't supports CUDA/OpenGL.
by fused » Wed Aug 15, 2012 9:07 pm
SmartDen wrote:Linux 32 GUI Build still crash on my computer. I suppose it is becouse i don't have supported video card or my card don't supports CUDA/OpenGL.
Hey Denis,
could we get some more info? When you run the Indigo ui from the terminal, does it print an error? Which distribution are you using? What graphics hardware do you have?
by CTZn » Wed Aug 15, 2012 11:48 pm
You've got a new private message.
by StompinTom » Sun Aug 19, 2012 4:11 am
Setting a precedence of 1 for Transparent Specular materials makes a black image:
EDIT: Precedence of 2 works just fine...
- Precedence: 10
EV +0
- Precedence: 1
EV +10
by StompinTom » Sun Aug 19, 2012 4:22 am
Also:
- Make cube around scene with Transparent Specular material, no absorption, IOR 1.0, Uniform scattering of about 0.01.
- Start Indigo.
- Select the fog medium, change Scattering from None to Shader, type in something (def eval(vec3 pos) vec3 :
vec3(fbm(pos * 1.0, 3) * 10.0))
- Rendering won't start (SPS and SPP stay at 0)
- Disable Shader or set back to None (for Scattering)
- Rendering still won't start, Indigo sometimes locks up
Seems there's a problem with using Shaders with scattering media? Just seems to hang...
EDIT: Maybe it works after a very long time. Seems to go extremely slowly after a long warmup.
Users browsing this forum: No registered users and 114 guests
