Indigo Renderer and Indigo RT 3.0.12
Re: Indigo Renderer and Indigo RT 3.0.12
Hi neo0., exponent is grayed out to signify that it can't be desactivated but the parameter is accessible if you click on it.
Ah, thanks for the info, ctzn! I will try that!
There's one more thing.. Not very major, but I noticed some aliasing (or jaggies I guess) artifacts in the early stage of a render. Bug by some small chance?
- Borgleader
I doubt it's a bug, aliasing is usually an artifact found in games due to how the sampling is done and all the shortcuts graphics cards take to maintain high framerates. Do you have a screenshot?neo0. wrote:Ah, thanks for the info, ctzn! I will try that!
Sadly, I didn't take one.. But I had never seen such a thing in indigo before. It was wierd.Borgleader wrote:I doubt it's a bug, aliasing is usually an artifact found in games due to how the sampling is done and all the shortcuts graphics cards take to maintain high framerates. Do you have a screenshot?neo0. wrote:Ah, thanks for the info, ctzn! I will try that!
maybe u set higher ringing ?
The "a", "b", and "c" parameters for bump maps are confusing for me. Im trying to increase the strength of the bump map but im not really sure which one is what. Are there any plans to change things to some more noob friendly?
Using the "b" parameter should do the trick. Remember that Indigo dimensions are in meters ;-)
Users browsing this forum: No registered users and 109 guests
